Rear door lock/central locking.
Afternoon all….!
I have replaced my rear door lock and swapped the barrel over. Easy job…
All went back to together smoothly. However, now my central locking doesn’t lock the door and the key also doesn’t. It did before I swapped in the new mechanism.
The central locking is working when and the key barrel is also. I feel like it’s more of an alignment issue, possibly? The door is latching and opening fine, that alignment is fine. There also doesn’t seem like there is much movement for alignment either.
Hopefully it’s just something daft that I’ve missed.
Just to update this. It was my fault. Adjusted the stricker on the body and it worked as it should.2017 5.0 V8 Supercharged RRS SVR
2008 2.4 110 Utility Station Wagon XS.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
