![]() | Home > Td5 > Remap not advised. |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 1052 ![]() ![]() ![]() |
Alive tuning will do a health check before progressing. I believe he did a 250,000 mile TD5 recently on his YouTube channel. 2017 5.0 V8 Supercharged RRS SVR
2008 2.4 110 Utility Station Wagon XS. |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 567 ![]() ![]() ![]() |
I run a 2005 Td5 with 196,000miles (315364km), It had a map on in before I bought the vehicle @ 28,000miles. I put a Turbo Technics S208 turbo on it 12 years ago and since a CJM manifold.
I do alot of towing and do like a 'spirited' drive, it has been a great vehicle. So no I do not agree the mileage is too high at all. Cheers Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2228 ![]() ![]() ![]() |
Chat to Empire Tuning they have agents in France. Any age and mileage TD5 can be mapped but mapping will highlight any potential issues you have now that you may not notice. As always a full health check would be done before hand. |
revd Member Since: 20 Apr 2024 Location: England Posts: 278 ![]() ![]() |
I won't be remapping my Td5, I am getting used to enjoying life in the slow lane.
I wonder if your man in Albi has had problems with remapped high milers when the time comes to pay a visit to the centre de Contrôle Technique agréé - is the diesel emissions test the same in France as UK? |
o4dn Member Since: 08 Jan 2010 Location: South West Posts: 591 ![]() ![]() ![]() |
Yes, indeed, I reckon it's the same. There is no actual exhaust gas analysis (yet) during the test. However, when not done right, a remap might increase smoke on charge, and opacity is tested. “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique. -- 2009 2.4 Puma Defender 90 SW 1979 Land Rover Series 3 88" |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1328 ![]() ![]() ![]() |
My 2003 unmodified Td5 failed the Control Technique on smoke opacity (3.60 - should be less than 3).
Added some injector cleaning fluid product stuff and went for a good thrashing - normally it just potters around on country lanes - short-ish trips. Also change the brand new expensive but faulty LR thermostat with a much cheaper and working OEM so that the engine would actually reach operating temperature. Retest passed with 0.17. I would think the initial failure was just build up deposits liberating themselves during the test routine. Or maybe the that cleaner actually did something? When you remap all you can really do is add more fuel under load which if pushed will create black smoke, but when they test they just rev it unloaded. Maybe you can ask if the remap would affect the CT test? |
