Home > Off Topic > interesting reading re toyotas so called greatnessl
sasha2001
Russia 2008 Defender 110 Puma 2.4 CSW Tonga Green
worth a read re findings of different FWD, shopshire Lad might get a shock!!!
in Australia
http://www.aulro.com/afvb/general-chat/788...yotas.html
Post #10620 10th May 2009 5:33am
enfrance
France 1995 Defender 90 300 Tdi SW Cairns Blue
You know what, there were hardly any complaints in all the replies.
But so many people said that Toyotas like all the othr big Nip brands are boring, is that because they are generally so bloody reliable ?
Post #10635 10th May 2009 5:45pm
sasha2001
Well I think its a personal thing, but there were quite a few wxamples of how there are failure from all brands after time and if they are overloaded etc
I persinally like toyote but no seven seaters and my toyota mechanic friend here does do very well fixing them as well as Landrovers!!!,
Post #10640 10th May 2009 8:18pm
AndrewS
That may be the case. But when you do break your 4x4 Jeeptoyotaaudimitsubishimastif off road they will invalidate your warranty because you used it off road. Land Rover however will collect/recover you from wherever you are and fix the problem FOC.
Post #10671 11th May 2009 3:16pm
Sonic3d
United Kingdom 2010 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
I for one can second that Thumbs Up and clean it for you Rolling with laughter
And give you another 4x4 so you can still play Rolling with laughter
Post #10694 11th May 2009 9:07pm
sasha2001
Interesting talking to a person here who installs extra fuel filters on cars and tractors, he was called by a farmer with a new 70 series V8 diesel
Put in some fuel with water from a farm tank, engine farted etc but he got away with it, just as well apparently 8 new injectors fuel rail tank etc is at present NZ$40000!!!!!, he wanted an extra filter put in for protection as the system may only have one filter? , anyway rang toyota NZ tech, they do not want to be involved, the filter guy said I know of 2 other v8s with problems like this, toyota guy said said he knows of up to 9 others!!! in NZ, its not a warranty problem so bye bye, So the new V8 engine had a fault with the wrong piston rings which were glazing up the bores and using a sump full of oil in 500km, this they had to fix and have a mod for this but boy if you are unlucky with bad fuel bye bye car!!!
At least even the new puma has a better filtering system!! apparently corect me if I am wrong
THe toyota guy admitted new Hi lux costs about $18000 and they have problems with these also, all admited off the record of course
Interesting!!!!
Post #11728 9th Jun 2009 4:21am
