![]() | Home > Puma (Tdci) > PUMA OEM radio wiring diagram |
| Marius Member Since: 21 Dec 2010 Location: South Africa Posts: 231
Does anyone have the PUMA OEM radio wiring diagram (colours etc....)
| yaho Member Since: 26 Nov 2008 Location: Bialystok Posts: 200
Isn't it standard ISO connector? Like here:
http://fordtransit.org/forum/viewtopic.php?f=54&t=78130 I have replaced OEM with Kenwood KDC-BT60U and it is simple plug&play switch. Janusz www.yahodeville.com |
| mse Member Since: 06 Apr 2008 Location: UK Posts: 5117
it is standard - what do you need? Mike
| dgardel Member Since: 30 Nov 2008 Location: Veneto (Heart & Head) Posts: 3586
Socket A and socket B (ISO-DIN Connector pin-out), forgot C1, C2, C3
Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated
IID Pro MV License |
Thanks for the diagram. Just what I needed. In the end the alpine head unit fitted into the oem connectors.
reversing lamp signal is needed for the NAVI unit like mine. and yes I have the Becker cd charger unit installed (inside the armored Mantec cubby) Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated
DGARDEL, Where did you get that temperature meter in the dash?
| TallPaul Member Since: 28 Aug 2007 Location: Nr Reading Posts: 270
C1 is usually for an external amp in high end units C2 is usually phone connection and steering wheel controls C3 is usually CD changer bus Assuming almost standard mainstream german unit wiring Having speed sense on the block already is very useful, is it definitely there in the Defender?! EDIT: AH I just realised that's your becker unit manual not the Defender wiring XS 110 Utility maybe one day..... (did they fix the quality yet?) |
| TheTechnobear Member Since: 28 Jan 2011 Location: Guadix, Spain Posts: 54
I've just attempted to install a new alpine unit in the truck, and the unit appears to have no power
Checked fuses, and they are fine. Can anyone tell me how the wiring is connected usually, i.e. where does the cable to the OEM plugs run to? Whilst installing I found a couple of oddities, and I'm wondering if the wiring has been messed with... cabling seemed to tidied away with sticky tape, and seems to run down LH side of centre console in foot well - I'm guessing this is not standard LR (for a defender that came from LR radio ready, no unit) Also the attenae connection, seem very very tight... Not sure it fits really! |
| XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632
I put an Alpine CDE-126BT in mine a few month back, and it simply plugged into thr LR loom and everthing worked perfectly. No cutting or splicing or anything unusual required. Maybe yours has been interfered with.
Pete |
| All times are GMT |
