![]() | Home > Td5 > Help needed TD5 ecu not powering up |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5983 ![]() ![]() |
Do you have 12v going to the underseat relay/fuse board?
gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 654 ![]() ![]() ![]() |
Yes 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 672 ![]() ![]() ![]() |
When you turn on the ingnition, does it light MIL and GLOW lights on instruments board? If not, and all fuses and relays ar OK, you ECU is not working - not running software inside. With never NNN type ECUs, it is not uncommon, that engine ECU fail this way. It is often repairable. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3269 ![]() ![]() |
ECU has likely failed, exactly the same symptoms as mine, just stopped dead.
No EML or temp gauge, no relay, no fuel pump, no glow plug light Try Mastaz in Hazel Grove Cheshire (google Mastaz TD5) l gave my ECU to him so he could copy the injector codes on to a replacement, but he repaired it for £80 l bought a spare ECU off him anyway in case it happens again, he charges £700 for those but the likelihood is he'll repair your old one. On mine it was a single resistor that had failed. |
Thanks mate I will contact him 2014 - current ..... 2003 defender td5 90 (my car)
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6199 ![]() ![]() ![]() |
What was the outcome of this gazman?
Shrubby69 Member Since: 30 Aug 2024 Location: Tunbridge wells Posts: 1 ![]() ![]() ![]() |
Hi Gazman - I have exactly the same issues that you had. What’s was the fix in the end? Cheers
Notyalc Member Since: 27 Jul 2018 Location: Northumberland Posts: 170 ![]() ![]() ![]() |
Ive just had the same story. The board in my ECU had started to delaminate in between the several layers (there are 5 or 6 i think).
Spoke to several people about repair or replacement. I went with Gareth at Empire Tuning in the end. Sure enough when i sent him my ECU he gave the bad news that the board was fubar. He was able to supply a replacement with a new map in a couple of days. Great service. I was up and running again within a week so well happy. |
1jjuk Member Since: 15 Apr 2025 Location: Midlands Posts: 1 ![]() ![]() ![]() |
I had same symptoms, turned out to be the middle yellow relay.
sorry all, missed this thread and only found it looking back.
The out come of mine if it helps anyone was i had lost one of the 2 earths from one of the plugs. When the two black earth were ran to ground the landy came back to life. I have still never found the cause as I have just ran from the ECU plug to a local earth point. 2014 - current ..... 2003 defender td5 90 (my car) 2009 - current .... 2005 zx10r |
