![]() | Home > For Sale & Wanted > F/S Patriot Roofrack Ladder |
ben_j85jty Member Since: 03 Sep 2008 Location: Bicester, Oxfordshire Posts: 491 ![]() ![]() ![]() |
I am guessing its for a 90 rack? 2002 Defender 110 DC
Would it be different for a 110 or 90 then Ben? John http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
The luggage rail would be a different length, which while not a major issue, I would prefer the full length. 2002 Defender 110 DC
Ah good point - I missed the bit about the rail and just read the ladder bit - Doh!
![]() http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
driver Member Since: 02 Aug 2009 Location: bude , cornwall Posts: 206 ![]() ![]() ![]() |
Sorry,
should have said the rails are for a 2.0m roofrack which is on my 90. |
Nick T Member Since: 29 May 2011 Location: Bolton Posts: 203 ![]() ![]() ![]() |
Any chance of some dimensions and a photo. I need a ladder but my rack is a Big Country. If it will fit I will take it. Cheers.
As I am at work tonight all I have been able to do is some measurments.
distance from crossmember bolts to holes in the roofrack where the top of the ladder bolts on: 1m 34cm distance between the 2 bolt holes on the roofrack where the ladder secures :12cm These are give or take a couple of mm as its cats and dogs outside and done by torch light, If you look on Patriots website there are plenty of pics there or this months lroi mag the bloke of the house in the country program has exactly the same set up on his 90. but I will try and do some pic's tomorrow, hope this helps. |
