Home > Technical > Turning Ignition, Power gone
hunting_defender
Austria 2015 Defender 110 Other SW Orkney Grey
Hi all,
I’ve got a 2015 Defender 2.2L TD4, and I’ve been experiencing an odd issue that I’m hoping someone might have come across before.
When I put the key in and turn it to the first notch (just before cranking the engine), sometimes the power cuts out entirely. It doesn’t happen every time – just occasionally – but it’s enough to make me wonder if something is on its way out.
Has anyone else had a similar problem? I’m not sure if it’s an issue with the ignition barrel itself, the key, or something deeper in the ignition system. Is this a known fault, or am I looking at needing to replace the ignition barrel or the whole switch assembly? Or battery?
When I put on 12V power to the battery, car comes back to life!
Any advice, experience, or pointers would be really appreciated!
Cheers,
Hubert
Post #1063501 21st Mar 2025 10:14am
Ianh
It could be a relay, ignition switch ( you can change just switch and keep barrel) or connection to ignition switch. Have a look at this topic on the relays in the seat box. Check relays labled 1 and 2 in the picture to see they are seated ok and operating ok.
https://www.defender2.net/forum/topic33868.html
Post #1063522 21st Mar 2025 1:15pm
PaulSanderson
Hi Ian - thanks for the info. My relay/fuse configuration seems very different to that of the OP in the threads link you kindly sent me - this being said, i checked relays #2 and #3 and theyre very much connected - i even had to loosen the fuse holder to get a hold of them!
Ive just priced up the ignition switch - seems a cheap enough piece to get, and will look into how much of a pig of a job itll be to replace Smile
In the process of resecuring my battery +ve clamp i managed to sheer the tightening bolt so need to get a few more bits anyway.
Post #1063525 21st Mar 2025 1:57pm
Ianh
That’s odd as it’s for the 2.2 underseat relay and fuse layout and is the same on my 2013 2.2. Perhaps the very last DSC equipped defenders changed the fuse and relay box layouts.
Regarding ignition switch replacement. These topics should help.
https://www.defender2.net/forum/post672697.html#672697
https://www.defender2.net/forum/post933318.html#933318
Post #1063534 21st Mar 2025 3:18pm
PaulSanderson
Thanks Ian - im beginning to see this could be a right pig of a job!! oh joy ...
As for the fuse box, it actually looks like this.
Post #1063536 21st Mar 2025 3:28pm
hunting_defender
Thank you for the answers - where do I find the ignition switch? Any part number? the relays are below the seat - any one of them likely to fail?
How would the power be restored when connecting a booster?
Could it be that the battery is in its way out
Post #1063540 21st Mar 2025 3:54pm
PaulSanderson
So the investigation ive done so far is that the ignition switch is at the back of the ignition barrel - need to dismantle the steering column (i,e,steering wheel off, disconnect wipers/indicator stalks etc). Some people leave the ignition barrel in-situ and access the switch from the back, and others remove the whole assembly - but its a bit of a pig to do, and involves either drifting out shear bolts, or cutting through them.
as for relays, it seems 2 are critical to the ignition -#2 and #3 in the box below the drivers seat.
I dont have half a clue what im talking about, having only checked these components myself today - but got some GREAT advice from members of this forum. suffice to say its running now, but only a matter of time before it fails again.
As for battery, just check the voltage in the battery itself, below the passenger seat - anything aout 12.5VDC and you should be good to go.
Also, here is a "hot to" for replacing the ignition switch - https://www.defender2.net/forum/post672697.html#672697
Again, provided by another VERY helpful member, not my info.
Post #1063547 21st Mar 2025 5:05pm
Main ground issue is common, but still shows as voltage in range, but voltage drop will be high under load.
When parked up for a while, voltage drops a little bit more 9ver time which is why it can seem to be worse in that scenario.
I’d look at voltage live, during cranking and see what that looks like, bearing in mind momentarily down to about 9v is normal, but if it goes down to say 5v then high impedance is the issue.
It’s common, for these things to come loose due to weather conditions, vibration etc.
It’s not a cure all solution, but it’s entirely possible. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1063565 21st Mar 2025 8:15pm
PaulSanderson
Not wanting to hijack the thread - you mean to check battery voltage or another voltage pre, during, and post-ignition?
Post #1063572 21st Mar 2025 10:08pm
hunting_defender
complete voltage - nothing works, radio sations are lost, clock stops etc.
Post #1063585 22nd Mar 2025 7:05am
PaulSanderson
Have you checked battery voltage, and then mega fuse on the red positive terminal? Got immobilizer light on?
Post #1063601 22nd Mar 2025 11:10am
hunting_defender
I changed the battery today, seems to have worked
Post #1063622 22nd Mar 2025 6:12pm
PaulSanderson
Perfect!!! About the easiest fix you can get.
Post #1063640 22nd Mar 2025 9:13pm
