![]() | Home > Technical > Removal of diff lock knob |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 891 ![]() ![]() ![]() |
Try harder!....should be threaded on to the lever shaft.
Big Juss Member Since: 03 Mar 2025 Location: Sunny South Coast Posts: 16 ![]() ![]() ![]() |
Thanks for your response, that's what I hoped to hear -- I'll wrap it in rubber sheet for a bit of extra grip. I only want to take it off so I can install the missing foam pad under the gaiter - it's so noisy!!!
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6047 ![]() ![]() |
There isn’t a grub screw holding it on is there?
True....there could be a grub screw!
johnlad Member Since: 18 Dec 2023 Location: Blackpool Posts: 104 ![]() ![]() |
No grub screw if it’s the same as mine but I had to use thread lock on it to stop it vibrating, maybe yours is similar
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1359 ![]() ![]() ![]() |
Mine had no grub screw and it kept unscrewing itself, unless I tightened it up at a weird angle. So I quick installed a grub screw and all has been well since.
Maybe someone was a bit lazier and as said just locktighted it. Might need a lot of force to unscrew. |
No grub screw, maybe locktite or just on really tight. I've got hold of some really sticky/grippy rubber sheet so I'll wrap it in that and try my oil filter tool tomorrow
Thanks for everyone's help |
