Home > Td5 > Hard to start
mustafasoleiman
United Kingdom 2003 Defender 90 Td5 XS CSW Indus Silver
Hard to start
Hello Forum members,
I replaced the battery a year ago and starting up my TD5 was a breeze until the last few days... Now it takes a lot of tries for the engine to start and when it does it gives up a lot of smoke.
It then runs fine until the next restart... The battery seems strong... What might it be?
Best
Alex http://instagram.com/h4vou/
Post #1063326 19th Mar 2025 10:46am
jim4244
England 2013 Defender 90 Puma 2.2 CSW Fuji White
Hi
Sounds as if your glow plugs need replacing.
Jim
Post #1063331 19th Mar 2025 12:04pm
landy andy
Try priming the fuel system before a start , and see if the results are the same or better.
Post #1063349 19th Mar 2025 9:06pm
Ianh
You can test your glow plugs in situ with a multi meter, should be circa 0.9 Ohm for each glow plug
Also check your glow plug relay.
Post #1063352 19th Mar 2025 9:42pm
Notyalc
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
A good TD5 should not need glow plugs, i would suspect fuel pump or pressure regulator if its a fuel issue. Crank sensor is a possibility maybe??
Post #1063357 19th Mar 2025 10:23pm
Battery ground loose, possibly, hence why it’s happened apparently suddenly.
If you have a long enough one, run a jump lead from the connected battery ground lead, to the engine block.
See what that does, if it solves the issue it’s ground, if not then the glow plugs might be failing.
I’d have thought if it was the starter it’d either pack up, or be running. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1063358 19th Mar 2025 10:57pm
jst
Alot of tries being alot of cranks?
Does it do it everything? Or only certain times? First start of day, any cold start etc. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1063371 20th Mar 2025 7:24am
mustafasoleiman
Thank you everybody...
What is the difference between try and cranK? I turn the key and the starter does its job without the engine starting or starting and dying immediately... then eventually the engine starts with a lot of smoke.
First time of the day but also after having driven it for half an hour or so.
Thanks
Post #1063402 20th Mar 2025 1:40pm
jim4244
What colour is the exhaust?
Jim
Post #1063411 20th Mar 2025 2:50pm
landy andy
Thanks
Alex
I think people are asking if it keeps turning over, but the engine doesn’t start, or do you turn key and the engine doesn’t turn over.
Have you tried a fuel pump prime procedure before starting. This will show if you are getting air into the fuel system
Post #1063422 20th Mar 2025 4:57pm
mustafasoleiman
The engine does turn over but does not start, then it does but does not stay on... then eventually it does... I think the smile is white.
I'll try the prime procedure this w/e.
Thank you!
A http://instagram.com/h4vou/
Post #1063520 21st Mar 2025 1:02pm
