![]() | Home > Td5 > Help with cooling system needed |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5969 ![]() ![]() |
So your problem is that it was at 100 centigrade ?
Everything else is ok. If that is the case I would not be overly concerned. I’d expect it to be in the 90 degree range anyway Thermostat starts to open ar 85 and fully open about 90. So by the time the thermostat opens closes it’s going to be a bit higher than that. A diesel engine wants to be at least 90 Take it on a good run and see how it goes. |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8315 ![]() ![]() ![]() |
Does nanocom take head temps of hose temp? The former I expect. Cheers
Jabberwocky Member Since: 27 Oct 2021 Location: Luxembourg Posts: 240 ![]() ![]() |
Yes the 100* and the Nanocom doing an overheating alarm freaked me out, having done a bit of reading I think I stopped the test drive too early, I’ll take it out again and see what happens, thanks for the reply. |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 671 ![]() ![]() ![]() |
With Nanocom look also at other temperatures - at least fuel is cooled by watter and has separate temperature sensor. And don't just look for actual values, but check, it there is rise or fall acconring to car/engine run. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
Had a check of mine this morning. 10c at start. Drove 4 gentle miles to where I was working, never went above 40mph, arrived with temp at 95c. I’ve had the nano temp scare before now you mention it, and think you can alter the threshold. But 100 isn’t unusual. |
Yeah having done a bit of reading the temps don’t seem as scarily high as I’d thought. Any further testing was put on hold when I discovered a fuel leak, new pressure regulator ordered🙄 another job to do.
I did notice the header tank cap wasn’t as tight as it could have been so maybe the system wasn’t pressurising as it should be. |
