Home > Technical > My 110 won't start
Irish rover
Ireland
My 110 won't start
Hi, I've just replaced my bulkhead on my 2999 td5 110 and all went good, until trying to start her?? It will crank over but no sound from fuel punp, no engine light and temp gauge goes immediately up to red?? I've checked the fuel pump relay 👍 and I haven't went bead the back of the Defender when doing the Bulkhead, so it must be up front? The previous owner had lots of dodgy wiring for spot lights and a alarm, I removed all these and was left with basic defender loom, I'm no electricians 😕 so if you can help me in layman terms I would be very grateful.
Thank you
Post #1063259 18th Mar 2025 2:07pm
Irish rover
Ireland
1999 Defender 🙄, big fingers, small keypad😁
Post #1063261 18th Mar 2025 2:08pm
revd
removing the alarm may have upset the inbuilt immobiliser
Post #1063267 18th Mar 2025 2:48pm
Irish rover
Ireland
Yes I'm starting to think that? Everything else is working lights, wipees etc, starter and battery are strong, I just can't figure out why the fuel pump and the engine light are not working??? It's recking my head 🤪
Post #1063277 18th Mar 2025 3:58pm
Ashbyandy
England 2015 Defender 110 Puma 2.2 Adventure Phoenix Orange
With the temp gauge going into the red, it sounds like it might possibly be an earth problem. Have you reconnected the bulkhead earth wires where you must have disconnected them, ie in the engine bay etc, just a thought,
Ashby Andy 👍
Post #1063278 18th Mar 2025 4:03pm
landy andy
The emergency fuel cut off button is connected and reset???
Post #1063284 18th Mar 2025 5:16pm
Irish rover
Ireland
Thanks everyone, yet I've been checking the earth's I will get the wiring diagram and double check, these wiring diagrams are not easy to follow, unless your an auto electrician,which I am definitely not 🤔. Where is the emergency fuel cut off switch??
Post #1063292 18th Mar 2025 8:05pm
rustandoil
Fuel cut off is on the bulkhead just about and to the right of the clutch resivoir (viewed from the front)
Edit.... Between the coolant resivoir and air box
Post #1063295 18th Mar 2025 8:34pm
Irish rover
Ireland
I know it was fitted, but I will check the connections,but it's still a problem to check with the engine light issue, I will check the earth's tomorrow 🤞
Post #1063296 18th Mar 2025 8:53pm
