![]() | Home > Faults & Fixes (L663) > It’s loose pipe? Reasonable doubt !! |
| lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3336
There's no way that's right. What engine do you have? l will take a look on mine if you have the D250
| mse Member Since: 06 Apr 2008 Location: UK Posts: 5112
thats right its been on everyone i have
I think its the washer breather...but normal Mike |
| ruben Member Since: 04 Feb 2021 Location: ASTURIAS Posts: 362
Yes, D250.thanks! Defender 110 SE I6 D250 23MY ExDiscovery 3 TDV6 SE |
What a strange technical solution, that of a tube abandoned to its fate and fortune in an engine bay, right? Although, truth be told, I hadn't noticed it until now... so one might think that, right up until now, it worked well or I was abducted or idiotized by LR and now I've woken up.🥵 or maybe my faith is wavering!! 😂 Defender 110 SE I6 D250 23MY ExDiscovery 3 TDV6 SE |
it cant hurt anything Mike
correct!! but it is not serious!! Defender 110 SE I6 D250 23MY
I stand corrected! But seems a bit shoddy to have a hose just hanging there, should at least be a clip holding it to something. |
| Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2763
I’m sure it’s usually clipped to the washer bottle filler somewhere.
| sasa Member Since: 05 Mar 2024 Location: ceska lipa Posts: 69
Click image to enlarge |
So I understand that it's just put there? Well, thank you very much for the solution,It is only attached and not connected to anything, since there is no connection at all I'll proceed accordingly. Thanks, Sasa. Defender 110 SE I6 D250 23MY
yes, only put there
The adventurous pipe has returned to its fold, poor stray sheep, sad fate for the engine bay hose!! Photo in progress!!
As promised, the bird is in its nest. Greetings from, finally, sunny Asturias. Happy Tuesday, everyone, and thank you!!
Click image to enlarge Defender 110 SE I6 D250 23MY ExDiscovery 3 TDV6 SE |
With leaves are oranges and tangerines, rare here, without leaves are what we call "pomares" that is, apple trees to make cider at home or eat acid apples!!
Click image to enlarge Defender 110 SE I6 D250 23MY ExDiscovery 3 TDV6 SE Last edited by ruben on 18th Mar 2025 2:42pm. Edited 1 time in total |
