Home > Td5 > The TD5 "left turn groan"
jonny
Hi All
It seems that quite a few TD5s have a 'groan' in the steering, only at low speed or stationary, and only when turning left. It sounds a bit like an old iron gate with rusty hinges closing. Right turns at low speed or stationary are silent, as are left turns at higher speed.
Doing a search, it suggests that this isn't uncommon, it's a resonance 'somewhere' within 'something' - but has anyone ever got to the bottom of what actually causes it? Cos it's blooming annoying!
PAS fluid levels are fine, can't see that it's anything major as it only ever makes a noise in one direction!
Jon
Post #1062898 14th Mar 2025 3:59pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
The box is telling you need s a rebuild. If its not leaking just keep driving it. Mine has groaned for about five years. Thumbs Up 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #1062916 14th Mar 2025 6:23pm
jonny
As far as I am aware, the box is only a few years old, although it was a recon one fitted by the previous owner.
From searching on here and some of the other forums, some owners TD5s have done it from new, but I've not been able to find out if it's the box itself, or something else (pump / pipework etc) resonating..
Post #1062919 14th Mar 2025 7:09pm
jst
Is it not one of the pipes resonating? I forget which one now but there was a reroute or new pipe for early td5s. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1062937 14th Mar 2025 10:08pm
I’d consider changing the PAS fluid, I expect it’s ancient.
Very often hardly gets changed, it’s often long life, but still, it’s possible it’s gone hydroscopic. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1062942 14th Mar 2025 11:17pm
jonny
It's a 2003 so not that early, but worth looking into - thanks..
Post #1062972 15th Mar 2025 10:51am
Mo Murphy
Have you bled the box to check there's no air on it ?
50 Shades of Pennine Grey
Post #1062984 15th Mar 2025 11:50am
jonny
Not yet, but it's on my list of things to do...
Post #1063000 15th Mar 2025 12:58pm
