Home > Technical > What’s this connector for?
Weston18
England 1999 Defender 110 300 Tdi DCPU Tonga Green
Situated in the passenger compartment fuse box in a ‘02 TD5. Any advice?
Also have a few other plugs that are disconnected. Trying to diagnose the A/c not working at the minute.
Post #1062884 14th Mar 2025 2:13pm
Will@LRW
 1997 Defender 110 300 Tdi CSW Alpine White
It's not one I recognise and it's not the bulkhead loom to A/C one.
You can see all 2002 connectors here https://www.lrworkshop.com/connectors/defender-2002my
And here you can search connectors by wire colour https://www.lrworkshop.com/connectors/defender-2002my/colour
What are all the wire colours going into that connector? LR Workshop
New parts illustrations https://www.lrworkshop.com/diagrams/land-r...ed-corners
Find a Defender's history and spec: https://defender.lrworkshop.com
Post #1062989 15th Mar 2025 12:07pm
Martin
Site Admin
I can't find it on the wiring diagrams either, but it appears to be on the AC controls side of the AC wiring.
You can see the blue/black + white/green + black/grey + brown going off on the other branch behind the fuse box, this should be going to the brown connector C0277 connecting to C0786 mounted on the fuse box plate.
What are the wire colours, is it a 3 pin plug?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1062997 15th Mar 2025 12:30pm
PaulMc
A question regarding this connector was raised on LR4x4 10 years ago -
https://lr4x4.com/topic/93404-td5-connector-conundrum/
There was no definitive answer as to what it was for - but Mo Murphy (the OP) traced the wires back into the harness and determined where they were fed from. Paul.
Post #1063016 15th Mar 2025 3:29pm
Mo Murphy
Well remembered Paul !
To save reading the whole thread, I decided it was for rear air con.
I don't know if it is. But i thought it was the best explanation in the end.
50 Shades of Pennine Grey
Post #1063018 15th Mar 2025 4:06pm
Weston18
Thanks for the replies. Great knowledge.
My A/c investigation is still on going. Currently have no blower at all on the A/c, I think I’ve located the blower relay, just left of the blower controls? I’ll check voltage there.
When I turn the blue dial I hear the engine note change, so something is happening there. Should the blower work regardless of blue dial position?
Thanks all
Post #1063028 15th Mar 2025 6:24pm
Weston18
Thanks all
Post #1063029 15th Mar 2025 6:39pm
