![]() | Home > For Sale & Wanted > [Wanted] Salisbury disc axle for a 110 |
MarkBrown Member Since: 03 Oct 2022 Location: Mid Wales Posts: 574 ![]() ![]() ![]() |
When I was building my 110 I bought a disc braked Salisbury axle for it, but unfortunately it was absolutely ruined ( I didn’t remove the cover to check - If I did I wouldn’t have bought it, but that’s hindsight ) so I used the original axle and converted to discs with mainly new parts and second hand front hubs. This has been great as the original axle was in good order with low mileage, clean oil and possibly little towing. All I needed to fit was a new drive flange and seal, along with a strip down and clean. I’ve also got two complete spare centre axles ( less brakes ) for it, should I need a replacement. 1983 110 automatic OM606
DR.Pepper Defender Member Since: 06 Jan 2025 Location: Yeovil , somerset Posts: 6 ![]() ![]() ![]() |
ok then, so I may be better buying the brackets and converting mine from discs... my axle is in decent condition with very little wear on the diff so that may be a better option.
thanks mark, giving me all the help today! much appreciated. Many defenders..... Many series.... Many Range Rovers... Got a problem.... |
lfletch Member Since: 10 Mar 2025 Location: oxford Posts: 2 ![]() ![]() ![]() |
Hi, Are you still looking for a Salisbury axle? I've recently taken one off my 200tdi 110. I did the disc brake conversion on it.
Hello, yea still on the lookout for one, where abouts are you based?
Thanks Dom Many defenders..... Many series.... Many Range Rovers... Got a problem.... |
I'm based in south oxfordshire. I also have a galvanised salisbury axle casing that I was going to swap everything over to but never got around to it.
