Home > Puma (Tdci) > Puma engine cuts out when idling or low revs when cold
Benji
Evenin all, i'm looking for ideas to resolve an issue with my 2007 defender 90 that is worst when the engine is cold - it cuts out when idling or low revs (e.g. when changing down a gear or braking quickly and slipping clutch). It takes about 10 mins for the engine to warm up, then the problem stops and runs smoothly. Definitely worse on frosty mornings, when its almost impossible to manouver out of my drive as I have to keep the engine above 1500 revs or it dies.
mechanic has replaced EGR valve and temperature sensor to no avail and nothing showing up on diagnostics.
Typically, the problem never shows at the garage as its a 10 min drive away!
Thanks Smile
Post #511838 7th Mar 2016 11:34pm
Christian1402
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Indus Silver
I've got a similar problem. Does yours hesitate on acceleration sometimes too? If when going from first to second, there's no power for about 2 or 3 seconds, then it pulls like normal?
Mine also hunts at idle
Post #512520 9th Mar 2016 6:17pm
Benji
It's fine accelerating, but cuts out when the revs drop and has just started to hunt when cruising when the engine is cold. Currently a frustrating mystery! Getting worse by the day - need some warmer weather!
Post #512678 10th Mar 2016 12:49am
Eduardo
Guys,
I had a similar issue some time ago: RPMs in idle come down and up and finally the engine cuts. Also with the time the acceleration was also involved.
In our case turn to be the MAF doing erroneus lectures. After change the MAF the problen dissapears 100%
Cheers and good luck Eduardo
Post #512679 10th Mar 2016 1:04am
There are several - even many - things that could be contributing to this sort of running on a Puma.
The first thing I would do is check whether there are any DTCs stored on the ECU, since if there are it may save a lot of wasted time. In fact, the absence of any stored DTCs may also save wasted time, since if there is none it suggests that the problem is in an area not monitored by the ECU.
Possible causes that spring to mind are the EGR valve, MAF, MAP, or CHT sensors, or a fault with the fuel system. Hunting at idle especially when cold can be caused by a defective VCV or uncalibrated fuel pump.
Post #512723 10th Mar 2016 10:07am
Christian1402
Thanks for the info. Am I right in thinking the tdci runs off nanocom, same soft wear as the td5?
Post #512729 10th Mar 2016 10:20am
Nanocom can be used on the TDCi, but requires different software due to the engine ECU and instrument pack being CANbus based.
Post #512753 10th Mar 2016 11:26am
Christian1402
I see, I'll have to see if there is anyone local with the equipment/soft wear
Thanks, and sorry for hijacking the thread!
Post #513030 10th Mar 2016 11:27pm
Benji
Thanks all, v useful - and I spoke too soon - started to hunt on acceleration yesterday! Lots to try...
Post #513081 11th Mar 2016 8:30am
Christian1402
If you find a solution to the problem please share, of course ill do the same if/when I find out what's wrong with it!
Post #513102 11th Mar 2016 9:28am
jst
Likewise, i am interested to see how you get on Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #513118 11th Mar 2016 10:31am
Benji
Warm weather today for first time in a while and it ran perfectly, so definitely cold related.
Post #514019 13th Mar 2016 11:32pm
Tigertim
Hey guys, I’m having exactly the same trouble as this with my 2007 110 puma 2.4, I realise this thread is from a while ago but any help/advise/feedback on causes would be great!
Thanks!
Post #1062331 7th Mar 2025 11:44pm
Ianh
Use code reader to see if there are any Diagnostic Trouble codes. You can get a cheap Bluetooth one on line and free apps or torque pro for £5.
If No DTC’s are recorded then this points to the VCV. Do a search on here and you will find a huge number of topics on faulty VCV’s for the 2.4
Post #1062335 8th Mar 2025 12:45am
Naks
yeah, VCV is the culprit here --
Post #1062345 8th Mar 2025 7:18am
