Home > Puma (Tdci) > A/C fan looks wrong?
jim4244
England 2013 Defender 90 Puma 2.2 CSW Fuji White
Hi all
Working on my daughters 2007 Puma.
Have a look at the photo below. The A/C fan and condenser look as if they have been fitted back to front?
Thoughts?
Jim
Post #1062177 6th Mar 2025 12:58pm
hank
That's correct. It is an aftermarket condenser with the original fan fitted.
The aftermarket condenser is bigger/designed for hotter climates.
I have the same condenser fitted and opted for a bigger fan that fits to the tabs provided as shown below
 > 110 XS Double Cab
Post #1062180 6th Mar 2025 1:39pm
jim4244
Thanks Hank Thumbs Up
Not used to Defenders having A/C…
Jim
Post #1062185 6th Mar 2025 2:21pm
jbcollier
Canada 2009 Defender 110 Puma 2.4 SW Alpine White
That is not an original fan. It is way, way undersized. Land Rover AC fans are powerful and draw serious current. Most off-the-shelf rad fans are not up to the job.
PS: Whoever installed it should be shot without a chance to make peace with their maker. Steel bolts through an aluminium heat exchanger?!
Post #1062333 8th Mar 2025 12:13am
jim4244
JB, my thoughts exactly!
However the A/C blows ice cold.
Jim
Post #1062352 8th Mar 2025 9:39am
Dinnu
It does look like the original fan to me, less a chunk of the mesh/grille. Landrover also mounted the fan with steel bolts through the condenser!
Missing bumper bolts because the condenser takes more space? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1062354 8th Mar 2025 10:16am
piechipsandpeas
Australia 2013 Defender 110 Puma 2.2 SW Indus Silver
Here's a shot of mine, original condenser and fan (2013) bolted straight through the condenser. Laughing
According to the JLR parts diagrams that looks as though it was designed like that and they hadn't just run out of brackets at Solihull on those days.
Post #1062363 8th Mar 2025 1:11pm
jbcollier
I'm still "agin" it! (wink)
Post #1062369 8th Mar 2025 2:38pm
shanecl
Ireland 1989 Defender 90 V8 Petrol CSW Auto Firenze Red
hank wrote:
Hank did yours come black or did you spray it black
Post #1062499 10th Mar 2025 9:17am
hank
It came black Thumbs Up > 110 XS Double Cab
Post #1062527 10th Mar 2025 3:25pm
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
this is how it's supposed to look like Laughing
(original MY 2015)
Post #1062824 13th Mar 2025 7:24pm
cechurap
Czech Republic 2010 Defender 90 Puma 2.4 PU Alpine White
Hello Hank,
please could you be so kind and have a look for the part nr. of the bigger SPAL fan?
I have bought the same aftermarket condenser - NRF 350489 and I am not sure, which fan will fit there..
Many thanks.
Petr
Post #1062925 14th Mar 2025 8:09pm
jbcollier
I'm about to fit the same condenser:
This fan bolts right in:
14 Inch 1,841 CFM Spal Electric Fan IX-30102056
https://www.summitracing.com/parts/SPU-IX-30102056
Post #1062928 14th Mar 2025 8:48pm
cechurap
Great! Thank you very much Bow down
Post #1062978 15th Mar 2025 11:10am
jim4244
Re: A/C fan looks wrong?
jim4244 wrote:
Hi all
Thoughts?
Jim
This set up still doesn't look right to me..
It looks as if the frame for the original Land Rover condenser has been used to mount the replacement aftermarket one?
Should the old frame not have been removed?
Jim
Post #1063004 15th Mar 2025 1:37pm
