Home > BMW Engine Conversions > M57 Conversion coolant problem
willyj
United Kingdom 2011 Defender 110 Puma 2.4 USW Stornoway Grey
Hi all,
My M57 doesn't have the coolant in the expansion tank warm up at all and the engine is using oil.
Any ideas?
I would have thought after a long drive the coolant should be hot?
Post #1060654 15th Feb 2025 7:54pm
Mo Murphy
Mine doesn't particularly get hot either but it doesnt concern me.
Turbo seals ? Valve stem seals ? Worn bores or rings ? Mine uses .5l every couple of months. I accept that on a 150k+ mile engine.
50 Shades of Pennine Grey
Post #1060668 15th Feb 2025 9:59pm
willyj
Thanks Mo,
I paid ~£24k for "Supply and fit full automatic 6 speed BMW M57 conversion £22,675.00 + VAT
300bhp
Inc. quality used BMW M57 engine (fully serviced at **** –
major overhaul), quality used automatic gearbox, full crate
conversion kit, BMW shifter, airlock, console, upgraded intercooler,
full exhaust, EGR blank and swirl flap delete"
Would like to have thought the engine wouldn't be in the condition it's in.
Plus the airlock for the difflock actuation they hadn't fitted it due to being "unreliable" only heard that after picking the vehicle up. They now have said they are happy to fit at an extra charge.
Post #1060792 17th Feb 2025 8:05pm
jst
That's alot of £££ but it does easily add up in parts alone.
Diff lock actuator off air,what's the problem with it? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1060805 17th Feb 2025 11:19pm
Mo Murphy
willyj wrote:
Thanks Mo,
300bhp
Wow, that's a lot of money ! The Land Rover 90 - Many are called, few are chosen.
Post #1060811 17th Feb 2025 11:48pm
Mo Murphy
Any progress @willyj ? The Land Rover 90 - Many are called, few are chosen.
Post #1061837 3rd Mar 2025 3:16pm
willyj
Having a bit of an issue with the garage that did the conversion. Not resolved yet. The garage said they sent me an old quote by accident but will put the airlock centre diff out of goodwill. I’m a bit puzzled they said that as there was 2 weeks from quote to having deposit including a couple of emails stating what was being done for the price etc.
hopefully will hear back this week. Not sure if I trust them to do it now if I’m honest. Had thought about getting legal with them as their attitude on emails isn’t good.
Will update more when I hear back.
Post #1062597 11th Mar 2025 12:42pm
willyj
A little update...
A little excerpt from their reply
" the engines we select do get tested prior to installation, the term overhauled is appropriate for the amount of work carried out on the donor engines here, we replace all essential gaskets, idlers, pulleys, ancillaries etc, anything it'll need to ensure a lasting conversion. We do not however delve into the internals of the engine as this would then be a reconditioned or rebuilt engine at a different cost. The engines are used, and as such will burn some oil, this is the nature of engines and there is a huge range of variables to consider, including towing usage. If an engine is working harder than usual, oil burning or use is to be expected. We inspected the bores of your engine and no excessive wear was recorded, an easy test to see engine wear on the internals is a blow by test – which you can test yourself, leave the engine running and remove the oil cap, gently place it back on. A severely worn engine will blow the cap off as it pressurises the oil galleries. I noted yours being a particularly good engine to use as a donor, and a very clean example at that."
I have never had an overhauled machine run through my company have such little done such as the reply. In fact I would say Overhauled and reconditioned are fairly similar in statements?
Am I wrong?
Post #1066082 22nd Apr 2025 8:14pm
jst
Overhauled change the easy bits, reconditioned change everything that can wear. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1066092 22nd Apr 2025 9:19pm
Simboii
Wales 2006 Defender 90 Td5 HT Keswick Green
Re: M57 Conversion coolant problem
willyj wrote:
Hi all,
Any ideas?
Mine doesnt seem to heat the water in the expansion tank either really!! More luke warm after a good drive!!
When you say using oil, how much are we talking??
Theres always going to be niggles with conversions like these, but get there one day!!
From Carmarthen too, nice to see a fellow m57 around this area!!
Post #1066416 26th Apr 2025 9:08pm
willyj
The plant equipment I run, when gets overhauled the pins, bushes are changed and engine wear is measured and pistons relined etc.
This was a £23k plus vat conversion and I don’t expect an engine to be burning almost half a litre every 1000miles plus the obvious sign of blue smoke coming out of the exhaust…
Post #1066564 28th Apr 2025 8:44pm
