![]() | Home > My Defender > Stornaway Grey Puma |
HuddyM Member Since: 28 Jan 2025 Location: Yorkshire Posts: 47 ![]() ![]() ![]() |
It’s a like for like cable swap. Remove old insert new. I did find on mine it had a tendency to slight forward sometimes. So I put a bit of double sided tape between it and the dash. 🤪 but if a bodge but it’s worked wonders 2009 Stornaway Grey Puma Build Thread
mptzs90 Member Since: 24 May 2024 Location: Kent Posts: 93 ![]() ![]() ![]() |
What did you have in there before? I have an alpine cde133bt and the cables def appear different. Looks like I have sw/f (assume subwoofer) and a single audio cable vs L/R and then the power etc is a different shape. Some research to be done!
EDIT... suspect I need to go down this path: https://www.mudstuff.co.uk/products/defend...1476558933 |
Ahh apologies, I didn’t realise there were multiple stock stereos. Mine was just the Land Rover branded one. Hope the wiring harness works. 2009 Stornaway Grey Puma Build Thread |
This is true, and touch wood, I’ve not been derailed by unreliability as of yet, so I’ve been blessed with being able to do pretty much what I want 😂 2009 Stornaway Grey Puma Build Thread |
Nah, no worries at all! that looks like an easy fix. wiring in the sub I'm much less sure of... I can't see any ref to how to do that on this model. |
Not sure I can be of much help, over and above reposting what it says on the amazon listing
"Please connect subwoofer or amplifier to the rear Audio Output (L-OUT/R-OUT) port." Maybe the helpful guys in the ICE topic can help. ![]() |
Ashamed to say I totally missed that in the amazon description - thanks!
There is a fair amount of pigeon English waffle on that page 😃 2009 Stornaway Grey Puma Build Thread
