![]() | Home > Modifications & Maintenance (L663) > Mirror Clearsight retrofit |
isugoo Member Since: 18 Feb 2025 Location: California Posts: 18 ![]() ![]() |
Thanks! I will skip the LR cable.
So your connection is: Mirror > Fakra cable (50 cm) > Camera/cover. That seems like do-able with my skill set. =D |
Darrant1234 Member Since: 03 Nov 2024 Location: Wakefield Posts: 24 ![]() ![]() |
You just need a female to female cable. I used a 5m in my 110 it’s too longs but works.
https://www.ebay.co.uk/itm/226306351839?mk...media=COPY |
Got it. I read entire threads again and got the idea that LR164584 is basically converting Female to Male connections. So if I buy Fakra Female to Female, I can eliminate and connect mirror and the camera with just one cable. For my Defender 90, I ordered 6 ft (1.82 m) female to female. I hope the length and connection works.
As I now fully ordered all the parts, I'll report back once I have all parts and installed. Thank you everyone for supporting my project! US Spec Defender 90, these are the parts I ordered: • LR1403340 Smart Mirror with Home Link - used from US 110 donor car https://www.ebay.com/itm/375814666311 • LR140535 Fin Camera (US specific) - suppose to come with the cover https://www.ebay.com/itm/386774670497 • Fakra Cable Female to Female (6 ft / 1.82 m) - cheap eBay version https://www.ebay.com/itm/133373277615 |
hmgt3 Member Since: 13 Nov 2023 Location: MCT Posts: 8 ![]() ![]() |
Hi. I want to attempt the mirror upgrade. My question is, what is the easiest way to get the plastic housing around the mirror arm off? It feels rather fragile. Don’t want to break it.
Thanks |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1445 ![]() ![]() ![]() |
I just used a trim removal tool like the one pictured and just carefully inserted it into the line down the middle of the trim and eased them apart.
![]() Click image to enlarge Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
Thank you. Will try that.
Colin68 Member Since: 18 Jul 2024 Location: Blackpool Posts: 117 ![]() ![]() |
I was a bit apprehensive but it came apart easy.
I tried to install yesterday but found out Fakra Cable 6 ft / 1.82 m wasn't long enough for D90. So I ordered 10 ft (3m). Will report back buys. Thanks! |
Just finished installing it with 12 ft. cable (6 ft. didn't work. 8 ft. maybe tight and 10 ft. would be enough but I just wanted to be sure so used 12 ft. cable) for my D90 and def. fishing wire is the hardest part. Other than that, everything went very smoothly. I coded Clearsight mirror via GAP Tool before install so the second I installed, Clearsight worked right away. Thanks everyone for the support!
By the way, I did radar detector hardwire same time as I already have exposed mirror harness.
Here is a picture of harness from another member who identified positive/negative wires. I used Blendmount's Mirror Tab 12" ![]() Click image to enlarge |
