![]() | Home > Wheels & Tyres (L663) > Gap between tyre and wheel arch 20" 5098s |
| TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1371
The rim/tire combination has an outer diameter and this should stay the same (for type approval, insurance etc). So by increasing the rim size your tire will get thinner and it would not make a difference in the clearance.
Now you could select a different tire (bigger) you would be outside of type approval, not sure how serious they look at that in the UK, but in Norway for instance you would fail your MOT and your gearing/speedometer/odometer would be off - the latter you might be able to correct in soft ware setting |
| STXdefender90 Member Since: 27 Feb 2025 Location: San Antonio Posts: 4
Get larger tires. 275/60/20 & since you have the stock 20 inch rims you should have no rubbing issues. There’s a guy on the forms that’s successfully installed this tire size, & iir looks sweet. Also, just so you can really have an idea of how much difference you’ll get out of different rims and tires check out this website, www.tiresize.com
| LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1314
As Texas said above, it's the wheel/tyre that has to be be the same rolling circumference. So the gap is the gap, sorry to say.
| ruben Member Since: 04 Feb 2021 Location: ASTURIAS Posts: 384
Or you can always drive in access mode, as long as your speed allows, and you will improve your situation somewhat!! 😅 Defender 110 SE I6 D250 23MY
ExDiscovery 3 TDV6 SE |
| Chicken Drumstick Member Since: 17 Aug 2020 Location: Near MK Posts: 921
Surely a 4x4 off road vehicle should have a gap??? Wouldn't most people want to increase the gap normally, hence the popularity of lift kits the World over for 4x4s. |
| USCG23 Member Since: 14 Jan 2025 Location: Arizona Posts: 34
A little gap is always needed.
I do see the fad in Japan with the defender 90s with a wide body kit slammed to the ground. It looks futuristic but you cannot go around driving like that. It looks great parked or at valet at an event but when it leaves it raised back up and off he goes. 23 LBW/Urban Defender X 20 Velar Autobiography |
Agreed 100%! 23 LBW/Urban Defender X 20 Velar Autobiography |
| DrRob Member Since: 29 Mar 2017 Location: Hampshire Posts: 274
Not on coil springs 1974 Series 3 Lightweight = "Millie" Many Range Rovers and Land Rovers over the years 😂 1949 80" - still in family since 1975 I use www.glenrands.co.uk Great independent specialist! |
| All times are GMT |
