Home > Technical > 2.0 MPI engine stuttering at certain throttle position
Luuk_def90
Netherlands
Good afternoon All,
I have a question regarding my Land Rover Defender 90, 2.0 MPI from 1997 (originally only delivered in Italy). The engine starts to stutter heavily at a certain throttle position. It happens in every gear. For example, if you drive in 2nd gear and give just a bit more than idle throttle, the engine starts to stutter heavily. The stuttering disappears when you give more or less throttle. This happens in all gears.
I have replaced the fuel filter and spark plugs, but this did not solve the problem. I have read on forums about sticky valves in this engine, but I find it strange that the problem only occurs at a certain throttle position.
Does anyone have an idea what the problem might be and how to solve it?
I look forward to reading your responses.
Best regards, Luuk
Post #1061330 25th Feb 2025 3:26pm
Bluest
My first thought would be ignition. I don't know what ignition system these engines have, but probably worth checking that first. 2007 110 TDCi Station Wagon XS
Post #1061339 25th Feb 2025 4:37pm
Chicken Drumstick
Does it feel like a fuel or electrical misfire?
Basic service items, plugs, leads, coil etc. Check these first.
Post #1061346 25th Feb 2025 5:17pm
Ianh
I believe the engine is a Rover 2.0L T16 DOHC petrol engine. https://en.m.wikipedia.org/wiki/Rover_T-series_engine
Post #1061353 25th Feb 2025 6:02pm
Bluest
Good engine back in the day. My Dad had a Rover 420GSI with one in and it absolutely flew. 2007 110 TDCi Station Wagon XS
Post #1061354 25th Feb 2025 6:05pm
lohr500
Interesting. I think that is the same engine that was offered in the UK Discovery 1's as well.
Is it a fly by wire type throttle control on the accelerator pedal, or a good old fashioned mechanica/cable linkage to the engine?
If fly by wire, I'm just wondering if the sensor on the accelerator pedal is playing up at a certain position.
Something in the back of my head is saying that later Disco 2's suffered from erratic throttle control due to failing pedal sensors. (And not sure if that was on the TD5 or the VCool. I'm sure I read something about how to check the sensor output using an ohmmeter.
I could be barking up totally the wrong tree though.
Post #1061356 25th Feb 2025 6:10pm
strang
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Galway Green
Yes it is. I had an MPI Disco 1 for a while. I can't help with the running issues sorry. I needed to change my thermostat on mine. but could not find it! I called into my local main dealer to see if they knew where it was but they didn't, so got the factory workshop manual out - it was still wrapped in cellophane as it had never been used before. They were pretty rare beasts. BTW thermostat located inside the top radiator hose! Euro-Leafing to infinity and beyond.....
Post #1061366 25th Feb 2025 8:17pm
mrdefendercarabinieri
Netherlands 1996 Defender 90 2.0 MPi HT Cairns Blue
Re: 2.0 MPI engine stuttering at certain throttle position
Luuk_def90 wrote:
Good afternoon All,
Best regards, Luuk
Hey i can help you with that
i have same car as you and i use to work a lot with them
Post #1067778 15th May 2025 1:23pm
Luuk_def90
Netherlands
Hi All,
Thanks for all of your feedback. After analysing the MEMS ecu it became clear the TPS (throttle position sensor) was the issue. After clearing all error codes, the issue disappeared. I have ordered a new PTS sensor and will replace it if the issue arises again.
Post #1068110 20th May 2025 8:28am
super !!! if you need some help just let me know
Post #1068111 20th May 2025 8:30am
