![]() | Home > Puma (Tdci) > 2.4 Puma losing fuel prime? |
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 823 ![]() ![]() |
Cheers Ian..
Yes I've had a Google now.. All my charts show the coarse as 1.75 , and fine as 1.25...the 1.5 pitch doesn't appear , but the books date to the 70's and 80's.. 🫣 |
There is no doubt about the pitch now.. I've have the necessary gauges , but didn't realise the 1.5 pitch was a common thread for m12..as it wasn't listed in my (admittedly old ) data..
After ians post i had a google.. The odd thing is even dealers didn't or wouldn't help me with information on a connector...and i was beginning to think it was only ever used for bleeding air, and not checking pressure.. |
I am going to make up a connector from brass fittings to allow a connection to the test point...
I did manage to lash up a fitting while I was away that allowed a connection and a check of the lp side pressure.. I did think I'd posted it earlier on on this thread but it appears not..🤔😫.. Anyway for anyone interested here is a trace showing from ignition on..if you don't start then the pump will cut out , and restart when the engine is running.. All easily seen in the trace alongside with the lp side fuel pressure to the hp pump.. ![]() Click image to enlarge |
