![]() | Home > Puma (Tdci) > Installation of Mudstuff Transmission Tunnel Matting? |
John P Member Since: 26 Dec 2013 Location: West Sussex Posts: 359 ![]() ![]() ![]() |
Has anybody installed one of these in a 2.4 TDCI?
https://www.mudstuff.co.uk/collections/car...tunnel-mat I'm about to install mine, but I cannot believe the heater assemble needs to be removed to install? I cannot find any installation information and there is nothing on YT. There are for other Defenders but not the 2.4? Any ideas? Thanks John |
Yes that’s the one. Can you remember if you cut the tunnel to slip around the back of the heater box? This makes the most sense to me, as there is a score mark on the tunnel mat. Just wanted to see if anyone else had done this.
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8369 ![]() ![]() ![]() |
it was a while ago but i dont believe i cut it. took gaiters off though. needs two people so thin bits dont rip. keep it warm prior to fitting too. well worth the effort. cant check mine as its under an auto console now. Cheers
bodstruck Member Since: 09 May 2020 Location: Wiltshire Posts: 1003 ![]() ![]() |
I would suggest giving Drew Wright a call to ask about fiting if it is one of his kits being resold. He was very helpful to me when I bought one for my defender.
shanecl Member Since: 20 Mar 2013 Location: Louth Posts: 549 ![]() ![]() ![]() |
I cut mine also as i realized after I had fitted the heater box and no way was I removing again, to be honest it also leave it easier to move it around later as I have had to do to install more sound deadening
Yes that makes sense, as it would be nice to be able to remove it easily for access to the gearbox etc. if needed. Thanks
mwestcrew Member Since: 09 Dec 2019 Location: South Warwickshire Posts: 288 ![]() ![]() ![]() |
I didn’t cut mine but it was a bit of a mare and a two man job because of the weight.
Seats out to give room for manoeuvre Worth every second of the struggle though. Makes a huge difference. 2011 130 Utility Body 2005 110 Van |
Got mine fitted last night. It has to be cut, unless you take the heater box out, which I wasn’t prepared to do. It went in fairly smoothly.
