![]() | Home > My Defender > Defender td5 help please |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2967 ![]() ![]() |
Split hose🤔
Chris86 Member Since: 15 Jul 2014 Location: South Yorks Posts: 802 ![]() ![]() ![]() |
Is the waste gate free? Chris |
jamesm26@icloud.com Member Since: 18 Feb 2024 Location: Surrey Posts: 10 ![]() ![]() |
Hi yes waste gate seems to be free and moving and I can’t see any split hoses or no noises of split hose
johnlad Member Since: 18 Dec 2023 Location: Blackpool Posts: 98 ![]() ![]() |
Possibly over boosting, has anyone been adjusting the length of the wastegate arm.
It was doing it before I brought it so I turned it one turn to the rite still did say so then turned it 2 turns to left still the same buddy
In standard tune I believe there should be 13 threads on the wastegate.
Ok thanks I will check it’s in garage now having service and boost pipes changed
Betsy Member Since: 05 Aug 2024 Location: Derbyshire Posts: 38 ![]() ![]() ![]() |
Mine was doing similar but kangarooing at high revs, I swapped the injector harness, freed the watergate as was stiff, cleaned injectors. Cleaned ECU plug, but non of the above helped then
I unplugged the MAF sensor and it appears to have cured it, I’m yet to replace the sensor however so it’s still unplugged but seems to run fine |
