![]() | Home > General & Technical (L663) > Gap Diagnostic Tool Activations for IID 4 tool + other items |
| TomekW Member Since: 21 Feb 2015 Location: Warsaw Posts: 197
exactly! so annoying that I am considering going back to original setting 2021 Defender 90 D250 1998 TUL 1997 TUM FFR 2003 Defender 110SW Td5 1985 ExMOD 110 ST 3.9 V8 1971 Series IIa Lightweight |
| Lonfred Member Since: 20 Sep 2024 Location: Barcelona Posts: 6
Hi,
Thanks for chairing your settings. What does this change do? MultiCAN-566 MHLastUserMode Last user memory mode disabled Last user memory mode enabled Does is remember the last driving mode? For example driving mode mud/ice will be remembered when starting car again? |
Hi,
this change remembers that I want to have auto start stop off 1998 TUL 1997 TUM FFR 2003 Defender 110SW Td5 1985 ExMOD 110 ST 3.9 V8 1971 Series IIa Lightweight |
| The_75th Member Since: 28 Apr 2023 Location: Devon Posts: 35
Wade Sensing...
...What might the differences be do y'all reckon? Click image to enlarge |
| Dannymm Member Since: 28 Jun 2024 Location: Wiltshire Posts: 20
Yes you have to have all these 3 setting to match MultiCAN - 838 Speedo Market MultiCAN - 577 SpdoCalPercentScale MultiCAN -575 SpdoCalkmhOffset |
| Brockmoor Howard Member Since: 12 Dec 2021 Location: antwerp Posts: 28
Hi Guys, has anybody info on what CCF modifications are needed for activating electronic active rear differential & torque vectoring by braking ?
| Muehae Member Since: 17 Jun 2023 Location: Erding Posts: 29
have you retrofitted a rear locking diff?
As i understand this, it not just a software adjustment, but a real part which is needed... |
| ruben Member Since: 04 Feb 2021 Location: ASTURIAS Posts: 381
Of course, it would be unthinkable that we would have a sleeping rear differential available at the price it has. Defender 110 SE I6 D250 23MY
ExDiscovery 3 TDV6 SE |
Indeed, a lot of configurations are sleeping in the CCF.
I was told by professionals that the differential is activable to become electronic. I wonder what EUCD/MULTICAN number is connected to that activation. |
| Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2785
The locking differential is a different physical part, it has a solenoid and extra wiring etc. as well as the actual differential itself.
It can be added but is a lot more work than just software. Have a read of this thread to get an idea of what is involved: https://www.defender2.net/forum/topic78820.html |
Thank you for this valuable info.
| lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3511
Have you tried this and did it work for you? When l tried it, l got various errors such as collision avoidance disabled and 2wd only available. l reset the settings and the faults disappeared. |
| Mark1107 Member Since: 19 Oct 2020 Location: Los Angeles Posts: 75
Fellas the locking rear differential can be oem factory retrofitted. I did it on my 2020.
https://www.instagram.com/p/CPcL8nNlhLw/?u...gn=loading Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge 2022 Defender Trek Competition 110 collectors edition! 2020 Defender 110 P400 Full Explorer Pack 7 Seater HSE Fuji White(sold) 2020 SVO Range Rover L405 Full Size Spectral Blue Chromaflair 2014 Range Rover L405 Autobiography Full Size Aintree Green 2014 Dodge Viper GTS Stryker Green |
| Cheshire110 Member Since: 26 Jul 2013 Location: London Posts: 2791
Has anyone found a way to set the Driver Assistance level (the steering wheel button on new models) to remember the user setting (like e.g. we have managed with start/stop)? Cheers, David
Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
