Home > Tdi > Should I?
Page 2 of 3 <123>
paul 123
United Kingdom 1995 Defender 90 300 Tdi HT Auto Rutland Red
i bought my 300tdi a bit better than that for 4000 the idea was patch it up convert to auto and have a cheap toy. new chassis bulkhead 2 1/2 years and about 4000 more its still in bits but getting there. i would offer 500 to 1000 and see where it goes its all about how badly you want it and how badly they want to sell.
Post #1060352 12th Feb 2025 1:39pm
Chicken Drumstick
I don't mind the 2.5TD, 89hp and was a sector leader in its day. But they don't like to be thrashed. Prone to cracking a piston.
I swapped a piston out on mine the other winter, engine in situ. Just don't plan to go anywhere quickly. Although, to be fair, they only feel slow on busy open bypass and dual carriage way roads. They make good low end grunt and have short gearing, so in places like Wales when you are in the hills and mountains on tight twisty roads, they actually feel quite lively, thanks to the turbo induced torque curve.
The Tdi is a much stouter engine with 107bhp from the factory and a lot more tunable. But they are less refined and more noisy.
Post #1060354 12th Feb 2025 1:42pm
The MoT history tells me that the rear chassis is shot, so at the very least major repairs are likely to be needed. If longevity is your aim, a new chassis.
If you want a farm hack that isn't going on the road it may make sense, but to refurbish it to the extent it becomes a nice vehicle will be significantly expensive. It would make a good project if that's what you want, and it could become nice. I suspect that it would cost more than it was worth at the end though.
I have a strong suspicion that that the current owner will not be happy with a realistic offer. Depending on how it runs and drives I'd be offering £750 to £1000 and no more.
Post #1060360 12th Feb 2025 2:10pm
Mo Murphy
For a long term doer-upper and keeper it's a good starting point. The Td engine is fine but will likely need pistons. With a more modern engine like a Tdi it'll keep up with traffic.
Be realistic with the chassis, if it needs a lot of work, rechassis and commit to this early on, it'll save money in the long run.
Offer him £500. Turn up with the cash in your pocket. Take it away before he changes his mind 😉
HTH
50 Shades of Pennine Grey
Post #1060366 12th Feb 2025 2:42pm
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
Chicken Drumstick wrote:
Often the chassis looks worse on the vehicle and once you've stripped it down for replacement, you'll see it probably wasn't as bad as first thought.
In my experience it's quite the opposite. Two chassis swaps that seemed an indulgent precaution at the outset, but once chopping up the old chassis for disposal it was definitely a case of thank goodness I didn't try to patch up the wafer thin remains!
I had an early 200tdi 90. I think it was registered April 1991ish and I'm pretty sure it was from the first couple of months production so a 1990 vehicle will definitely have originally been pre-tdi.
Post #1060368 12th Feb 2025 2:43pm
Norfolk-n-chance
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Santorini Black
I was thinking of offering £500, at that, my reasoning is that if it really is serious bad news then the sum of the parts would be worth more!
The sheep box on the back is worth about £100…. “a committee is a group of people who individually can do nothing, but as a group decide nothing can be done.”
Post #1060378 12th Feb 2025 3:27pm
... Often the chassis looks worse on the vehicle and once you've stripped it down for replacement, you'll see it probably wasn't as bad as first thought. ...
I didn't notice this comment previously but I am afraid that the complete opposite is the case in my experience - every chassis I have worked on has been much worse than it superficially looked. In the case of this Defender there is clearly significant rot in the rear spring/rear crossmember area.
Norfolk-n-chance wrote:
... The sheep box on the back is worth about £100….
If by "sheep box" you mean the IW canopy than either they fetch a premium in Norfolk or you may be in for a disappointment! I bought one that looked virtually brand new some time ago for £35 in Dorset. If it was a 110 double-cab canopy it would be worth more, but 90 canopies do not appear to be worth mush at all.
However if you can get the vehicle for £500 you won't have been ripped off and will certainly be able to get your money back in parts if it proves a money-pit.
Post #1060385 12th Feb 2025 4:48pm
Chicken Drumstick
@blackwolf, it is not clear at all. The MoT report is generic and non specific at best. Without physically seeing the vehicle, there is simply no way to know.
That said, you can buy a rear cross member with legs or even a rear half chassis. Which could be significantly less work to replace.
Now, I'm not saying this is the case here. But I'm yet to really see a chassis that was as bad as thought, once fully stripped down. They nearly always could have been repaired and done years or decades more service.
Post #1060396 12th Feb 2025 6:46pm
MarkBrown
Wales 1983 Defender 110 Other HT Auto Keswick Green
I paid £1200 for my 110 in 2018, off eBay, sight unseen. My main reasoning was that I wanted a project and I knew that once I had a base vehicle ( any 110 ) that my project had started.
I sold off the bits I didn't want and got a fair bit of the purchase cost back.
No truck, no project.
I'd go with £500 up to a max of £1000, providing the V5 is present, but it does depend on the end goal like others have said 1983 110 automatic OM606
Post #1060402 12th Feb 2025 7:39pm
Slideywindows
It has a Diesel Turbo engine, hence the DT on the DVLA site.
Land Rover never called them Turbo Diesels, as that was reserved for the diesel engine in the Range Rover.
Registered in May 1990, it will be a very late Ninety. (Defender introduced with the 200Tdi in September 1990).
Whichever way you look at it , it will be a money pit.
Farmers seldom abandon a vehicle which has much value left it it.
£500 probably won't get it though, because seller will think it is worth a fortune.
Despite that engine probably being totally knackered.
(Look for the paper air filter being contaminated with engine oil.....)
Post #1060407 12th Feb 2025 8:09pm
MarkBrown
At the risk of sounding like a nerd, I'm pretty sure that Land Rover badged them as a turbo. I recall my very first 110 turbo diesel had a turbo sticker on the back - this of course could have been a fake or indeed I could be wrong! 1983 110 automatic OM606
Post #1060409 12th Feb 2025 8:30pm
Chicken Drumstick
I think technically, Rover actually. branded them as Diesel Turbo. The then Range Rover could be had with the Turbo Diesel which was a VM sourced engine. And TDI was actually Turbo Direct Injection.
Post #1060415 12th Feb 2025 9:06pm
Mo Murphy
It was called the diesel turbo with its turbo sticker on the back.
Post #1060438 13th Feb 2025 8:31am
Will@LRW
 1997 Defender 110 300 Tdi CSW Alpine White
I reckon the seller will want £5k, if the project vehicles on eBay are anything to go by... LR Workshop
New parts illustrations https://www.lrworkshop.com/diagrams/land-r...ed-corners
Find a Defender's history and spec: https://defender.lrworkshop.com
Post #1060454 13th Feb 2025 11:03am
Norfolk-n-chance
I’ve got some more photos coming this weekend so will have more of an idea then. “a committee is a group of people who individually can do nothing, but as a group decide nothing can be done.”
Post #1060455 13th Feb 2025 11:07am
Page 2 of 3 <123>
