Home > Technical > Puma 2.2 gear change
Bradders130
United Kingdom 2012 Defender 130 Puma 2.2 HCPU Indus Silver
Just got my gearbox out for a slave cylinder and clutch change. Wouldn’t be such a bad job if it wasn't for that damn DPF which is a Censored to get out, to say the least.
Anyway, checked over the white nylon pivot ball at the bottom of the gear lever whilst it was out and found a fairly straight crack running down through the ball via steel spigot on one side. I don't think that the crack is supposed to be there, but it looks so straight that I’m thinking it was manufactured like that. Anyway, assuming that it isn’t, does anyone know if that lower section is available as an individual item as below or do I have to purchase the whole piece complete with aluminium housing and turret, etc as below...
Here is the part I’m talking about…
and the crack in the nylon ball…
Thanks in advance guys.
Post #1060079 9th Feb 2025 11:12pm
Ianh
See this video. It shows the same cut in the ball . Generally filled with grease.
Post #1060083 10th Feb 2025 1:52am
Bradders130
Thanks Ian. Do you know if I can get that bit separately?
Post #1060091 10th Feb 2025 10:00am
Ianh
I don’t think you can get it separately, if you fancy a short shift upgrade you get that plus a couple of other parts but the main casting is reused. However that’s approx £30 more than the full mechanism from LR.
Post #1060121 10th Feb 2025 2:30pm
It’s a whole assembly unfortunately, and the crack shouldn’t be there.
I had the same on mine, Ian is correct it should be very well greased up as well.
I fitted a TMD Shift R V2 I find it really good. Though strangely, when I had a look the other day I couldn’t see them for sale now?
There is a slick shift as well, but is a little different to the above.
If you have a crack like that in the nylon ball as you have, it makes for a very oddball gearchange and leads to a lot of excess unwanted movement in the gearstick. _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1060156 10th Feb 2025 8:04pm
Ianh
I’ve not taken one apart, but noticed in the video I posted ( 10 mins in ) that the slot was cut in the same place as the OP’s picture, so are you sure it’s not meant to be there or is this a common fault with the OP’s, yours and the one in the video. ?
Post #1060184 11th Feb 2025 12:08am
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
del
Post #1060191 11th Feb 2025 6:40am
Bradders130
That does seem very coincidental Ian. I have tried squeezing the crack back together, but it doesn’t move. May be it has been made that way??
Post #1060216 11th Feb 2025 11:26am
Ianh
I’ve been doing some searching, it does look like t SHOUD NOT have that slot / split in the ball. From looking a various pictures it appears that the ball fractures as the steel parts that go through the ball expand with heat and / or corrosion.
Just my guess from what I’ve seen in pictures, so I could be completely wrong.
Post #1060231 11th Feb 2025 2:09pm
Bradders130
Thanks Ian, I appreciate your help.
Post #1060232 11th Feb 2025 2:22pm
I think it’s fairly common but shouldn’t happen, I guess happens over time.
What it does do is produce a waggly gearstick and very vague gearstick change.
What is also a pain is the weights rattle, it will often come back even after a fix, needing fixing again.
Ideally it would be best if there was one created where the weights issue is fixed permanently.
I guess an all metal type might be better, but not so good to use when hot or cold in the hand. _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1060247 11th Feb 2025 7:39pm
Bradders130
Well, I’ve decided to take the plunge and buy a Slickshift. I didn’t think it was worth buying another Land Rover one which will inevitably throw a leg out the bed at some stage. It may turn out to be awful and hard to get into gear, in which case I will have to revert back, but as they say, nothing ventured nothing gained.
Post #1060323 12th Feb 2025 11:40am
Provided that the ball is not worn and is lubricated, I don't think that the crack actually makes any difference and really isn't a problem. The ball is, after all, contained in the plastic cage/cup and can't go anywhere.
I've never seen one where there is any evidence that the split ball is moving on the gear lever.
Post #1060362 12th Feb 2025 2:16pm
mwestcrew
United Kingdom 2011 Defender 130 Puma 2.4 HCPU Baltic Blue
I did SlickShift a couple of weeks ago. Top Tip: when you think there’s too much grease add some more.
Also make sure the recently added rubber ring at the top of the lever stays in place and add grease to the naked upper lever.
It’s very good. You’ll be surprised and at the same time wonder what the hell didn’t LR do it in the first place. 2011 130 Utility Body
2005 110 Van
Post #1060429 13th Feb 2025 12:52am
Bradders130
I bought the slickshift and it is fitted, and I have to say the difference is staggering. It is a different vehicle now and soooo much better. Any concerns I heard about, such as difficulty getting it into gear, are not there. It is brilliant and I definitely will not be going back.
I would definitely recommend getting one.
Post #1061899 3rd Mar 2025 10:11pm
