![]() | Home > Tdi > 300Tdi whiteish smoke when decelerating with partial throttl |
LEZ90 Member Since: 07 Feb 2025 Location: Brighton Posts: 3 ![]() ![]() ![]() |
Advise needed:
I picked up my first Defender a few days ago (300tdi, 1995, 80k, RC chassis and 2 owners) and noticed a problem on the 250 mile driver home. I’m getting a lot of whiteish smoke when decelerating with partial throttle. If I take my foot off it stops. It’s fine when under load, it’s only when I take my foot virtually off. Apart from that it drives fine. |
You got any more spare ones
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11031 ![]() ![]() |
![]() Put a " Wanted " thread up, there plenty on here that will sell you one ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Will@LRW Member Since: 04 May 2019 Location: UK Posts: 227 ![]() ![]() ![]() |
When was the timing belt last charged? LR Workshop
New parts illustrations https://www.lrworkshop.com/diagrams/land-r...ed-corners Find a Defender's history and spec: https://defender.lrworkshop.com |
not sure.
Its on my list once I've got it running right. |
It'd be worth checking the timing is correct to rule that out. Can do it without dismantling the front cover. Previous owners may have advanced or retarded the timing, or have set it wrong.
Then replacing the belt would be the next cheap thing to rule out before condemning the pump LR Workshop New parts illustrations https://www.lrworkshop.com/diagrams/land-r...ed-corners Find a Defender's history and spec: https://defender.lrworkshop.com |
Dave T Member Since: 07 Jun 2013 Location: Glasgow Posts: 492 ![]() ![]() ![]() |
If it’s a Delphi one there’s a single screw on the top which allows you to take the top off and clean the filter underneath it. 2015 RRS Autobiography SDV6
1994 Def 90 300tdi |
