Home > General & Technical (L663) > Replacing Discs and Pads
JAM911
Are there any guides out there to replacing the discs and pads on the L633 please?
Thank you
Post #1060154 10th Feb 2025 6:55pm
mse
I’ve done them on the last one
What dos you want to know
Other than the torque the rear has a brake release for the park brake but there’s nothing special
Take the wheels off both sides to turn the front for access Mike
Post #1060163 10th Feb 2025 8:17pm
Retroanaconda
Mine was pretty straightforward, basically the same as any modern floating caliper vehicle. If you don’t have a diagnostic tool you’ll need to use the fiddly sequence to wind the parking brake motors off on the rear.
You’ll need new bolts for the caliper carriers too, and replacement disc retaining screws are also a wise investment.
Post #1060175 10th Feb 2025 9:36pm
Kev the Rev
United Kingdom 2007 Defender 90 Puma 2.4 HT Keswick Green
There’s a video on PowerfulUK on YouTube where they upgrade the calipers.
Looks pretty straightforward
Post #1060180 10th Feb 2025 9:56pm
mse
Yes i didnt get the disc retaining and then quickly went to get them
There is a inappropriate term for how tight the caliper bolts were on mine - my heavy duty impact worked incredibly hard to get them off with all its fancy settings Mike
Post #1060218 11th Feb 2025 10:47am
JAM911
I have seen the Powerful UK video on how to release the parking brake.
What is the sequence to un release it?
Also any torque numbers?
Thanks
Post #1060221 11th Feb 2025 11:17am
mse
Install and tighten the 2 new brake caliper bolts.
Renew Part: Front brake caliper carrier bolt(s) - M16 X 40mm Quantity: 2. Part Number:
LR033274
Torque
Stage 1: 133Nm
Stage 2: 60 degrees
Install and tighten the 2 bolts.
Renew Part: Brake caliper carrier bolt(s) Quantity: 2.
Torque
Stage 1: 110Nm
Stage 2: 120°
Connect the EPB actuator electrical connector Mike
Post #1060306 12th Feb 2025 9:17am
JAM911
Thank you for the info.
Can you explain what the Stage 2: 120° means please?
Post #1060319 12th Feb 2025 10:17am
Brulz
Italy
If you don't know what it mean.... I suggest you do NOT replace Disc yourself!!!
Sorry about it... but if you do something wrong you are in truble!!!
The best will happens is vibration....
Post #1060379 12th Feb 2025 2:37pm
JAM911
It just means tighten more...thanks
Post #1060383 12th Feb 2025 3:30pm
mse
i would tend to agree
It means a specific additional rotation to set the right tightness. - the were Fing tight Mike
Post #1060453 13th Feb 2025 9:56am
