Home > Technical > Puma brake pipe size
ickle
I'm looking at swapping my servo for the abs conversion, tech says it might require two new brake pipes.
The current (plastic covered?) ones measure 4.83mm, I have a roll of uncoated Kunifer in stock that measure 4.55mm - as the seal is on the flared cone formed on the pipe, and there is no coating on the smaller pipe, am I correct in assuming this will be fine?
Cheers Keith
Post #1059418 3rd Feb 2025 8:13pm
MR_JAMES
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
3/16 is 4.76mm. perhaps 3/16 kunifer brake pipe would be better? 1953 80"
1987 mini city e
2011 90"
Post #1059800 7th Feb 2025 1:42pm
ickle
Thanks, the Kunifer I measure at 4.55mm is labelled 3/16 I think its so close and as it seals on the flare Ill give it a go - we will find out in a couple of weeks!
Post #1059821 7th Feb 2025 3:44pm
