Home > Puma (Tdci) > Puma 2.4 Overboost on Motorway
Page 1 of 3 123>
PipsterP10
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Hi all,
I've got an issue with my Twisted P10 2.4 Puma loosing power when cruising on a motorway.
To give you some background, it starts and idles perfectly, pulls smoothly through the gears. I can drive it hard on A'roads using full throttle through the gears if I want and never get any power loss. As soon as I hit a dual carriageway or motorway and cruise at a stay 60-70mph I don't get any warning lights but do get a loss of power as if in limp mode. As soon as I pull over and restart it's back to normal, once on the move again it might do it within 5-10mins or could be fine for another hour but I know it's going to do it again.
I've got a ICarsoft LR V3.0 and this is showing a P0234 Permanent Overboost code.
The turbo (standard) and intercooler (Twisted intercooler) were replaced in late 2021
EGR brand new 2 months ago
MAP sensor replaced last month (Genuine part)
MAF sensor replaced last month (Genuine part)
VCV replaced last month (Genuine part)
Turbo actuator brand new (Hella)
Turbo vanes are very free to move with no sticking
I think I've managed to capture the data on the iCarsoft as below as it went into limp mode, I did notice the temp at 104 is a little high??
If any of you on here can share any wisdom I'd very much appreciate it.
Cheers all.
Post #1059488 4th Feb 2025 12:57pm
Ianh
I would check your MAF connector and wiring to it, it can fracture / chafe at the connector and on the engine / engine components. Do the same for wiring to the turbo actuator.
Also check the hose from turbo to intercooler, check from under the vehicle, it can split / hole if it rubs on the steering column or other engine components.
Post #1059489 4th Feb 2025 1:11pm
andy63
I know it's been changed, but if your problem is always under cruising conditions, I can't help thinking egr valve ..that and of course what has been mentioned about other leaks, but you would think they would effect all driving modes..
Edit..and your mass air flow figures is far to low i think
Post #1059494 4th Feb 2025 1:42pm
Julie
France 2012 Defender 110 Puma 2.2 SW Keswick Green
Low air flow - > Turbo Hose ?
What about climbing ? Do you have enough torque ?
Just give it a blow on a steep motorway ans see the fault code + hose pop
Milestone
Post #1059498 4th Feb 2025 2:00pm
PipsterP10
Hi,
Thanks for all the comments, I’ll go and climb under and check the hoses.
There’s loads of torque until it goes into limp mode.
Post #1059515 4th Feb 2025 3:54pm
Johan_B
Sweden 2008 Defender 110 Puma 2.4 CSW Tonga Green
At what coolant temperature is engine protection triggered on the 2.2? Surely it should be higher than 104C but that temp seems a bit odd in this season. Could it have been higher before limp mode was activated? I'd look into the cooling system regardless just to make sure.
Post #1059519 4th Feb 2025 4:34pm
PipsterP10
Climbed back underneath and inspected the intercooler to turbo hose, found a small area of abrasion and although I couldn’t see a hole I’m betting it’s leaking. New silicone hoses on order so hopefully will be sorted once fitted.
Will let you know………..
Post #1059524 4th Feb 2025 5:38pm
Julie
Mine was split on the bottom side. I didn'it réalize unless unmounted.
And check the sensors for dirt. Especially those for air. They countercheck - and transmit default values if not consistent. There's a table in the workshop manual.
Post #1059528 4th Feb 2025 6:30pm
jst
I had similar to this, carbon build up on vanes of turbo, they wouldn't move quick enough when changing accelerator input. Alwaysnhappeneded after sitting at constant speed for a while at 60/70mph then say hitting a hill.
Mine was a 2007, 2.4, 70ish k.
Drove well with changing accelerator.demands over a roads et and could be driven hard too, no problems.
Sit cruising at constant speed and it would hit. Cycle ignition to reset it. No dash lights.
Revive sorted it. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1059553 4th Feb 2025 11:21pm
andy63
That's good info..
So the op can monitor live data and should see a much slower and perhaps an overall reduction in boost pressure when the fault occurs..
Worth a look .👍
Post #1059568 5th Feb 2025 11:02am
jst
Yep i believe the turbo became temporarily fixed vane after a prolonged period of constant boost. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1059588 5th Feb 2025 4:21pm
I’ve found that to happen once due to sticky non lubed Turbo Actuator pivots.
The vanes were free, but the above can cause that.
A bit of periodic 3in1 oil on them, and never had an issue since. Very Happy _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1059611 5th Feb 2025 7:11pm
jst
Yep, common with actuator going. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1059640 5th Feb 2025 10:34pm
andy63
I'll stick this on here as we are on about turbos and actuators..
I have the 2.2l
A 5 wire actuator connector..
Pins 3. 4 .5 all appear to be part of the actuator position signal, with a 5v ref
A ground and a signal which takes the form of a pulsed square wave signal..
The duty cycle of the pulse..ie the amount of time it is grounded seems to determine the vanes position..
First trace is ign on..the 2nd Is at tick over..the pulse width ie frequency are the same but the amount of time it's grounded varies..
Pins 1 and 2 are the motor connections. Fed by most probably an H bridge arrangement, and depending on what pin is supplied determines the direction of rotation..
A trace showing the two pins been supplied as the accelerator is pressed
And a closer look at one of those voltages showing its negative duty cycle and controlled by the ecu..
The green is the motor current
Post #1059711 6th Feb 2025 7:00pm
PipsterP10
Hi all,
So, fitted new Alive Tuning silicone hoses yesterday, ran perfectly as before on a roads, took it onto a dual carriageway today and after 5 mins back into limp mode with a permanent Overboost error code again Banging Head
My thoughts now are to just change the whole turbo, the actuator in new and the vanes feel completely free as does the connection rod but I’m thinking it must be the issue.
I love it to bits but it’s getting frustrating that I can only drive it locally without it going into limp mode.
Any advice on a good turbo supplier?
Post #1059808 7th Feb 2025 2:29pm
Page 1 of 3 123>
