![]() | Home > Faults & Fixes (L663) > 25MY Defender Gearbox Engagement Delay |
| six13 Member Since: 22 Jan 2025 Location: Pretoria Posts: 5
Just an update. My D350 is going to the dealer on Wednesday for a software update that apparently may fix this issue. So, it seems that they are now more aware of the issue and looking for a solution.I will post an update to let you know if it worked. Let's hold thumbs.
| discobean Member Since: 06 Jan 2025 Location: Sydney Posts: 15
If it does fix it and your dealer has a service bulletin or any official information they can for the rest of our dealers that would be fantastic
| Flinders Member Since: 17 Feb 2024 Location: West Yorkshire Posts: 91
I hope it does work. They tried twice to sort my rejected D350.
First attempt lists as ‘carry out a 2F adaptation drive cycle’. The second attempt lists as ‘run a gear box calibration as required’. None of these resolved it. It also went to JLR Tech for the solution on both occasions and the dealer had to wait a few days for any suggested solutions. I’m hoping there is a solution before my replacement arrives! MY25 Defender 90 D350 X Dynamic HSE - Boris - REJECTED MY18 Discovery 5 3.0ltr TD6 HSE Lux - Derek |
| LandyLover1107 Member Since: 23 Dec 2024 Location: NA Posts: 14
six13, I'm looking forward to your update. If it does resolve the issue, please would you mind asking your dealer for the bulletin reference number so we can all share with our dealers? Like discobean also mentioned. Crossing all fingers and holding thumbs! |
| mse Member Since: 06 Apr 2008 Location: UK Posts: 5117
I’m having this issue with my d350, it nearly ripped back into the bollard in my work car park trying to drive away. What was the fix? Mike |
Mse - unfortunately they didn’t fix it. I rejected the car. Just waiting replacement I ordered and hoping that one doesn’t have the same problem! MY25.5 Defender 90 D350 X Dynamic HSE - Maximus
Annoying, the rest of the car is fine - but this rolling problem is annoying, ill have to book it in Mike
Unfortunately, it didn't fix the issue. Not sure what they did but they updated a bunch of software. They also topped up the gearbox oil as suggested. But the issue is still there. As you said it is so annoying as this is the only issue I have with the car. I have learned how to manage stops and traffic light stops - but one shouldn't have to do that.
So back to square one! |
| billy2shots Member Since: 23 Oct 2024 Location: England Posts: 46
Dealer Visit
For info I don't use Hill Hold Took a tech out to show home the issue of rolling forward in R and backwards in D. Explanation Gear box slippage and perfectly normal apparently. Work around Press the break firmly down, this artificially puts on hill hold for 3 seconds whilst you manoeuvre away or change gear and move in the opposite direction. Not overly thrilled but if that's the design and common way of driving this box, what can I do |
| edwardsylvester Member Since: 08 Jan 2025 Location: watford Posts: 2
Hill hold/auto hold is a red herring. As soon as you touch the accelerator this is deactivated.
The issue is that the vehicle takes itself out of gear (even in Drive), so takes a second to go back into gear. During this time, hill hold is off and the vehicle is effectively in neutral. I have a contact at JLR head office and they have raised this to the appropriate team. My thoughts are that the fix it will be released as a remote software update at some point. |
Unfortunately that solution didn’t work on mine. It still rolled back on hills however hard I pressed on the brake.
The usual response of ‘normal they all do that’. …….. Not all of them do and the one I test drove to compare didn’t either. Just hope my new one that has a build date of today doesn’t have the same problem! MY25 Defender 90 D350 X Dynamic HSE - Boris - REJECTED MY18 Discovery 5 3.0ltr TD6 HSE Lux - Derek |
Such nonsense. It's not normal at all. No other automatic vehicle I have driven does that, not even the cheapest of them.
Must be a flaw in either the software or the torque converter. The gearbox/clutch disengages totally which should not happen. |
Its not normal, it didnt do it in my last one and some dont do it at all.
Talking about hill hold is missleading, as you dont need that on. No automatic rolls. None of my automatic land rovers roll when in drive Mike |
| jenzz Member Since: 14 Dec 2024 Location: Frankfurt Posts: 7
Took delivery of our D250 110 beginning of December. Done 4000km on it since, and the issue with rolling backwards and torque converter hesitant to engage is the only complaint. Today I was waiting at a traffic light on a slightly noticeable incline, it switched to green, and when I moved my foot from brake to accelerator pedal, the car was slightly rolling back, rear camera was engaging and the parking sensors began to ring because they sensed the car behind. This is pretty annoying.
I just set my hopes on an upcoming OTA Update, because this is so ridiculous. |
