Home > Puma (Tdci) > Puma 2.4 blue smoke
Page 3 of 3 <123
lbdmp
France 2010 Defender 110 Puma 2.4 SW Nato Green
My turbo harness has no ferrite. Could this have an effect?
I installed a radio at the same time as the problem.
Post #1059325 2nd Feb 2025 9:40pm
MK
was the replacement engine coming from a Defender? Was it overhauled? any chance to check the pistons shape from the top? Injectors supplied by LR? Puma 110" SW
Post #1059334 2nd Feb 2025 11:04pm
jbcollier
Canada 2009 Defender 110 Puma 2.4 SW Alpine White
"My turbo harness has no ferrite"
What is a ferrite? (other than magnetic iron oxide)
Post #1059340 3rd Feb 2025 5:24am
lbdmp
All defenders seem to have this ferrite, but not on mine.
Can't this wire be disturbed by another signal?
Post #1059352 3rd Feb 2025 9:34am
andy63
I'm pretty sure my 2.2 has nothing like that .I was playing around at the turbo actuator connector a few weeks back and think I'd have noticed..
Just about all wires in the engine compartment can and will suffer electrical magnetic interference..I see it on the scope loads and it can be a pain. 😫..where they are really trying to avoid and minimise its effect the wires are usually twisted..as in the can network..and I think the injector wires.. I havnt stripped back the turbo actuator wires sheathing to see if they are also twisted..
That's assuming that's what the ferrite core is for...🤔
Post #1059354 3rd Feb 2025 9:56am
lbdmp
I'm also going to test my motor harness
Post #1059356 3rd Feb 2025 10:15am
andy63
I've just had a quick look, and while my Italian or whatever isn't great😫🤣
I think this is the turbo actuator connector and it shows the motor power supply wires as a twisted pair..👍
Post #1059357 3rd Feb 2025 10:34am
lbdmp
Thank you for this diagram.
This explains the ferrite in the repair kit.
Post #1059360 3rd Feb 2025 11:46am
jbcollier
Mine is a 2009 2.4 and has no magnet either.
Post #1059380 3rd Feb 2025 2:14pm
jim4244
England 2013 Defender 90 Puma 2.2 CSW Fuji White
Hi
Will the ferrite ring make that much of a difference?
I'm overseas at the moment so can't check if I have one on my 2.4.
Jim
Post #1059382 3rd Feb 2025 2:22pm
The ferrite wore through the insulation on mine and caused a failure of the actuator! Laughing
Only Land-Rover could achieve this....
Post #1059390 3rd Feb 2025 3:44pm
lbdmp
Hello,
I've had some time recently and I've restarted my defender.
I started by deleting the fault.
Miracle, no more smoke!
A week later, I wanted to run it and the smoke appeared again. No fault in the diagnosis.
I took 2 measurements of the sensors, what do you think? The intake pressure does not increase with rpm (test done in neutral).
Post #1061728 2nd Mar 2025 2:07pm
andy63
Manifold air pressures don't look right..
I'm assuming absoloute is atmospheric plus whatever the boost is.. in one set it's actually lower at 99kpa
Your mass air flows still look low to me ..
Again I'm assuming the bold figure is just a mean or average over trace time..and while they do rise and fall with accelerator demand the base value at idle is low..
You just have to investigate all possibilities from malfunctioning turbo , exhaust blockages, carboned up manifold which is effecting the map sensor...etc
Post #1061748 2nd Mar 2025 5:55pm
Caterham
me neither. I think they were a retrofit to solve something - but I can't recall what / why.
good luck.
Post #1061866 3rd Mar 2025 5:46pm
Page 3 of 3 <123
