Home > Td5 > Td5 diesel knock when engine hot
adseybear
Canada
Noticed now that diesel knock seems more and more pronounced when engine is fully up to temp.
Injectors?
https://youtube.com/shorts/G117vcS_fWs?si=x4HAXXo0tMtsXLiP 2003 Defender 90 Td5 CSW Belize Green - "Betty"
1958 Series IIA 109 Station Wagon - "Randolph" - Awaiting Restoration
2019 Jeep Wrangler JL Rubicon - SOLD
2006 Volvo V70 D5 - Ocean Race Edition, SOLD
2003 VW Passat Estate 1.9TDI - SOLD
2008 BMW 320D M Sport Estate - SOLD
2001 Defender 90 Td5 Hard Top - SOLD
Post #1059222 2nd Feb 2025 12:19am
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
What oil is in it? And is there enough? Injectors just click…
So knocking is bad! Could be many things. Check head gasket, timing chain, rockers… 🤷‍♂️
Good luck 2020 range Rover Mk IV Autobiography PHEV
2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #1059305 2nd Feb 2025 6:56pm
Hazza
United Kingdom 1990 Defender 110 Td5 HT Bronze Green
Does it change with clutch in/out? Could maybe be Dual Mass Flywheel? 1990 Defender 110 200TDI Camper - now converted to Td5 power
Post #1059347 3rd Feb 2025 8:30am
adseybear
Canada
Nope, it’s definite combustion diesel knock, not oil or anything related. Only on idle does it get loud and when engine is up to temp. All other driving scenarios it’s fine. 2003 Defender 90 Td5 CSW Belize Green - "Betty"
Post #1059398 3rd Feb 2025 4:36pm
DefenderCan
 2006 Defender 110 Td5 CSW Chawton White
I would bank on the injectors.... possibly the harness is giving incorrect signals.....
Here are some other possible things Ill spill off the cuff.....
big end or small end bearings but that's crazy work to find out
timing chain and tensioner can make a knock.
Your crank pulley could be delaminating this will also make a knock.
If you have a nanocom you can check your cylinder balances.....
In an extreme situation but unlikely, one of your injectors are leaking, pooled the bowl and on first combustion bent a rod.... again, very very rare but possible.
Post #1075843 21st Sep 2025 10:39am
