Home > For Sale & Wanted > [Sold] Seat rails/risers
excossack
For sale a pair of seat rails/risers (One pair is mudstuff)
https://www.mudstuff.co.uk/products/mud-se...kBTpqGfWnR
Fitted and used but I never really got on with them. While they provided the extra travel, I felt I was too high and my right leg was sort of caught under the door handle and with the wind deflectors on the side windows I felt I had to look under to see out. - I am 5'11
Come with fixings. One pair is tapered box section and the other pair is what looks like taper U section with a flat plate welded in to form a box. One pair has black end caps the other doesnt.
Some grease from when I lubed the runners but most has been wiped off. and some paint has chipped off where the bolts have been used to attach to the seat box.
Both pairs of rails sets (4 x rails) £40 with postage or if you want just one pair (2 x rails) £20 each pair + postage
 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #1059169 1st Feb 2025 12:28pm
julian
United Kingdom 1994 Defender 110 300 Tdi CSW Alpine White
I was considering some of these - do you have to drill additional holes in the seat box for them, or do they use the existing holes and then offset using the box?
Your photos make it look like no extra holes are needed, but I'm sure I read a fitting guide at some point what claimed cutting was required?
I find the standard driving position fine but my partner complains... Hence thinking about getting a set.
Thank you.
Edit: pending confirmation of the questions above, could I provisionally take the box section one with the end caps, which, I'm pretty sure, is mud stuff.
Post #1059175 1st Feb 2025 3:11pm
Jon w
Wales 1991 Defender 90 200 Tdi HT Epsom Green
Please can I take the mud stuff pair
Thanks
Post #1059205 1st Feb 2025 9:40pm
excossack
Jon W.
The mudstuff ones are pending sold. The others are still available if needed.
Should the mudstuff sale fall through I will let you know. 1999 Defender TD5 110
Regards
John M0VAZ
Post #1059238 2nd Feb 2025 9:55am
excossack
Just the one set of rails/risers left - Mudstuff ones are sold - thanks 1999 Defender TD5 110
Regards
John M0VAZ
Post #1059303 2nd Feb 2025 6:19pm
airpusher
Wales 2006 Defender 110 Td5 XS DCPU Zambezi Silver
Go on,
I’ll take the other set.
Lee 2006 Defender Double Cab- Zambezi Silver
Post #1059328 2nd Feb 2025 10:30pm
excossack
hi PM me some details please Lee and will sort it out for you
cheers 1999 Defender TD5 110
Regards
John M0VAZ
Post #1059409 3rd Feb 2025 7:10pm
excossack
Both items sold - thanks. 1999 Defender TD5 110
Regards
John M0VAZ
Post #1059506 4th Feb 2025 2:44pm
julian
To confirm -
The seat risers arrived here this morning, as advised, well packed and with no issues.
Thank you for a smooth transaction.
Post #1059576 5th Feb 2025 1:12pm
excossack
Thanks for letting me know all is good - thanks Julian 1999 Defender TD5 110
Regards
John M0VAZ
Post #1059580 5th Feb 2025 2:24pm
