![]() | Home > In Car Electronics > Wolfbox rear Camera |
| Gremlin110 Member Since: 26 Dec 2024 Location: Sevenoaks Posts: 1
I have a G930 from Wolfbox in my Puma 100. It's only been installed for a few days so i am still getting used to it. i've fiddled with some settings, but so far i am pretty impressed. I've installed my camera above my rear washer jet, and so far, apart from a hole that is currently letting in the rain (goop didnt arrive on the day expected and grommets are not big and also small enough) fitting it was pretty much a breeze - the ONLY complaint my mate had installing the hard wire bit of it was working out something to do with the fuses (i was, absolutely useless with the electricery stuff). I'll nab some photo's of what it's like when it's daylight and not raining
| Les Brock Member Since: 20 Mar 2012 Location: Stroud, Glos Posts: 187
I have a Jansite one, does everything I need it to:
Front, rear cam Front, rear or split screen Regards Les Def 90 M57 |
| HuddyM Member Since: 28 Jan 2025 Location: Yorkshire Posts: 47
I got the Wolfbox G900 Pro, had it for about two weeks before getting an auto electrician out to hard wire it in.
Thanks to my tracker, I’m able to keep an eye on the battery levels. Even with the parking mode on it’s barely touching the battery. The on screen icons can be a bit glaring at night time, but I hear a firmware update is on its way to adjust that. I mounted mine above the washer jet housing. I extended the hole used by the water pipe to save additional drilling into the landy. I used the included sticky pad to attach to the car, and despite numerous journeys and the fact it’s rained since Xmas day (feels that way) it’s still stuck on. I’m yet to get confident enough to trust the parking lines on the reverse display, but the quality of the videos are fantastic. I’m a little disappointed by the fouling of the sun visors, I’m weighing up cutting them down and recovering them, or moving the rearview screen. |
| ThreePointFive Member Since: 03 Jul 2012 Location: UK Posts: 226
I'll be grateful for a look, I need to do something with mine. One life - get one. |
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8406
when we do that wiring then! Cheers
