Home > P400e Area (L663) > Check engine light
Elbek
Check engine light
Today check engine light vent on, car is driving fine. I have connected gap tool, following errors came out, that would not clear. Any suggestions? I assume maybe a some fuse burned ?
Post #1056681 8th Jan 2025 4:32pm
Elbek
Post #1056682 8th Jan 2025 4:34pm
Ritson
France
My ‘check engine’ light has been coming on intermittently for the past 3 months. It has been back to the dealers 3 times and they have done a full diagnostic check and complete reboot but are still not able identify any fault or reason why ‘check engine’ light appears at random Current: MY22 P400e SE
Prior: Discovery Sport HSE, Jaguar F-Type S, Discovery 3, RR Vogue
Post #1056728 8th Jan 2025 11:20pm
Elbek
Unfortunately, there is not an official LR dealer in my country, I have imported the car from Austria. So today I have updated my Gap tool and plugged it in again, started the engine, and cleared the faults, they have not cleared, but engine sign on the faults has disappeared and the check engine light has gone. Drove the car for about 40 km, drives just fine and the check engine sign have not appeared again. Any thoughts?
Post #1056738 9th Jan 2025 6:32am
Brulz
Italy
Elbek wrote:
Bad news for you....
DTC P0A7F-00 come out when the High Voltage traction battery is deteriorated..
You need a Topix to do the diagnostic test to confirm the problem.
I see also a BECM DTC... maybe you can try to solve the problem with a BECM firmware update.
The last fw version is L8B2-14C268-AG.
Cancel DTC, update the BECM and 🤞...
If the light come out again, the problem is more complex....
See my topic
https://www.defender2.net/forum/topic93114.html
Post #1056868 10th Jan 2025 10:48am
Elbek
Car is less then a year old. It has been 3 days, check engine light never came back again, car functions as normal, with no issues. I have done an over-the-air update, maybe it solved the problem.
Post #1057001 11th Jan 2025 6:50am
Ritson
France
Spoke to dealer today upon return from visit to UK. Explained the following issues:
Check engine light has been on for the past month I was in UK.
When running in electric in Hybrid mode the petrol engine would suddenly engage randomly and refuse to go back into electric
Car drops out of EV mode as soon as the A/C or heater turned on. (had this problem before and they replaced HT Heater)
Alert that I needed to start motor to charge battery, even though I'd just driven 1,200km the previous day.
When pure EV mode is selected it still uses petrol engine and the EV icon on the IDD is grey rather than blue
Frequent alerts that the SOS system is partially unavailable
He has immediately said that the Hybrid battery is the issue and he will order a replacement. Therefore this must be a know issue for them to have immediately volunteered to replace battery without even seeing the vehicle (though its been in twice in the previous 3 months for the same issues).
Glad I got the 5 year warranty! Current: MY22 P400e SE
Post #1058745 27th Jan 2025 8:09pm
Odin81
France
Good morning,
Can you say me if they finally changed the HV battery?
Post #1065836 19th Apr 2025 9:52am
Ritson
France
Yes they changed the main HV battery. No issues since they did that. Current: MY22 P400e SE
Post #1065843 19th Apr 2025 11:17am
Odin81
France
Thank you for your answer
Post #1065901 19th Apr 2025 8:59pm
