Home > Technical > Dc current to central door locking Actuator
Phillywilly72
United Kingdom 2011 Defender 110 Puma 2.4 DCPU Tamar Blue
Rear passenger central door locking has stopped working. Got access to the power cable supplying the actuator. Am I right in thinking a quick power dc voltage signal should be sent upon pressing the key fob? Hooked up my volt meter but nothing shows when setting it to dc 20v. Other doors work so not sure if power or actuator. Any other tests I can do? Thanks
Post #1058553 25th Jan 2025 4:35pm
landy andy
99 percent of time itโ€™s the wires from vehicle to door.
Post #1058555 25th Jan 2025 5:00pm
Phillywilly72
Going to the actuator is only two thin wires protected via some trunking.
Post #1058556 25th Jan 2025 5:04pm
landy andy
If there is only two wires (which there would be on a rear door) then that will be them
Post #1058558 25th Jan 2025 5:07pm
Phillywilly72
So the way I am testing is correct 20v dc on voltmeter
Post #1058560 25th Jan 2025 5:09pm
landy andy
Post #1058562 25th Jan 2025 5:11pm
landy andy
If you got to the B post you can pull out the rubber trucking that goes to the door and then pull out the connector that supplies the power to the central locking. Do your tests there. And also give the wires that go into the door a good pull. I think you will probably find a broken one or two.
Post #1058565 25th Jan 2025 5:20pm
Phillywilly72
Thanks
Post #1058566 25th Jan 2025 5:21pm
Phillywilly72
Landy Andy hit the nail on the head, broken wires between b pillar and door if anyone is interested.๐Ÿ‘
Post #1059335 2nd Feb 2025 11:24pm
