![]() | Home > Td5 > Engine hesitates when going into neutral |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1355 ![]() ![]() ![]() |
You mean as the rpm drop down to idle speed it seems to dip and then pick up again?
The Td5 cuts all fuel on over run and then picks up the fuel again at idle speed. This can sound a little its hesitating, but once you get used to it you don't notice it, assuming obviously it does not stall. Personally I quite like to sound as it really enforces the 'I am now idling and oh by the way - it's rocksteady' feeling compared to say petrol engines where the rpms just drop off with no distinctive moment where it's idling. |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6043 ![]() ![]() |
Agree. I would say what you are explaining is normal behaviour
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2508 ![]() ![]() ![]() |
no, I mean once it reaches back to idle speed and after 1-2 seconds I can feel the hesitation/vibration. Then it comes back to steady idle right away. Resembles a little misfire in one or two consecutive injection. Puma 110" SW
achuakh Member Since: 12 Apr 2012 Location: Singapore Posts: 161 ![]() ![]() ![]() |
check if the ECU receives road speed information.
contrary to what people believe that only the disco uses road speed info, the defender also uses it. The defender has migrated, leaving the owner behind. |
miker916 Member Since: 25 Oct 2022 Location: Fife Posts: 64 ![]() ![]() ![]() |
I asked exactly the same question when i first got my TD5, consensus is its perfectly normal.
https://www.defender2.net/forum/topic94365.html Cheers Mike |
