![]() | Home > My Defender > Fuji 110 LS3 build |
pistonfields Member Since: 29 Mar 2022 Location: Zurich Posts: 76 ![]() ![]() |
Thanks for de detailed explanation. yes, the rear view camera. PO mounted one under the spare wheel on the tailgate. I likely would only use it when parking, so no need for me to see the tow hitch.
The 3d printed part looks brilliant, very well done. Would you mind sharing the 3d files? Then I could fire up my own printer if I get myself that rear view mirror... wife has been complaining recently how usefull it would be. Guess I'm cleared to spend the money then ![]() |
mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2947 ![]() ![]() |
Let me get it all fully fitted and then I can help out.
What would people say is the best view from a rear camera? I don’t need to see the towbar so I guess if I just catch the edge of the spare? Has anyone any pictures of there rear camera view on screen to share before I fix it to the roof?? Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
NoLimits Member Since: 29 Dec 2022 Location: Somerset Posts: 60 ![]() ![]() ![]() |
You can scroll up and down on the screen to adjust the angle, I mounted mine high up by modifying the rear washer with 2 cameras, one as a rear view and the other to look down to the tow bar (I currently don’t have a wheel on the back)
![]() Click image to enlarge This image shows the screen in its central spot looking straight out but it does have about 10 degrees of angle up and down, the picture also shows the reversing camera on the main screen, beware that even up there they do get dirty. I used to have one below the spare wheel and that would become useless after a few miles in the winter. ![]() Click image to enlarge I used Ram mounts to fix mine up and at some point I will directly wire those cables in through the back of the unit Hope that helps ![]() Click image to enlarge |
Thanks for this, didnt know the angle had some adjustment in the setting
![]() 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
Another update on the most over engineered Wolfbox install
![]() The modified leg so that the cables can pass thru it... ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Then printed a connector cover which is still to be painted. ![]() Click image to enlarge ![]() Click image to enlarge Some printed spacers so the cables can run behind the mount ![]() Click image to enlarge ![]() Click image to enlarge So pretty much ready to fit it all up now. Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11074 ![]() ![]() |
Loving this Andy, the fit will be spot on
Thanks Clayton. Got it fitted this evening, just the hardwire power to hook up next.
![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
wow, as always, the attention is in the detail
So all fitted and hard wired in now. Took a bit longer as I needed to add some extra wires from the new bluesea fuse box for this and the winch cut off which I plan to finish tomorrow.
![]() Click image to enlarge Printed a mount for the rear camera.. ![]() Click image to enlarge GPS located here.. ![]() Click image to enlarge Used visors from Ebay trimmed to suit.. ![]() Click image to enlarge ![]() Click image to enlarge Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
Got to fit some leather this evening. Very pleased. Just some black nappa on the usual bits and perforated grab handle to match the adventure steering wheel. The sliding cubby lid is a hit, just needs to sit over night while its bonded on, rear cubby to do in the morning and then new seat belts. The only thing that didn't work out was the leather gaiter for the gear stick. I just don't have the space to gather all the leather so I may have an alloy surround machined with a simple slot for the travel and maybe add some letters for the positions, not sure
![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
Wee handy job this morning to fit the rear cubby. Its a standard cubby I modified, not as wide and floats over the sub. Then just a precision cut of a cup holder on the chop saw to fit it into place.
![]() Click image to enlarge ![]() Click image to enlarge 4x4 works have just got some nice warn accessories into stock as i have been looking for a bag for the remote and gloves. Went for the grab handle bag in the end on the rear door. ![]() Click image to enlarge Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
Fitted the Porsche Chalk belts today, nice to see a bit of contrast inside. Top class service as always from FDTS.
![]() ![]() Click image to enlarge Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2277 ![]() ![]() |
