![]() | Home > For Sale & Wanted (L663) > [SOLD] 11.4 pivi screen |
| LostCause Member Since: 07 Jan 2025 Location: Toronto Posts: 12
New to the forum so I cannot PM yet. Can you explain the connector? would I need to change pins or does this come with an adaptor for a direct fit replacement? I understand the housing in the dash is different and needs to be sourced separately. Tx
| Clark4x4 Member Since: 19 Jun 2023 Location: Madrid Posts: 39
Hi, the small connector are compatible with pins that came from current 10 inch screen, you just need to put pins in coorect position, you could check here --> https://www.defender2.net/forum/topic89297.html
I could provide detailed pictures of connection, no problem. Regards |
| mrfurgles Member Since: 22 Jan 2025 Location: Chicago, Illinois Posts: 2
First time poster, long time lurker. If still available, I'm an interested buyer. Thanks!
Hi,
yes, still available. You have PM Regards |
| Adams10 Member Since: 02 Mar 2025 Location: Massachusetts Posts: 3
Checking if this is still available? I'm deciding between 13.1" and 11.4", but if this is gone then that makes the decision! (also new and cant PM)
Hi, still available!!!
Regards |
Sending PM.
| All times are GMT |
