![]() | Home > Puma (Tdci) > coolant air locking |
jbcollier Member Since: 29 Apr 2024 Location: Edmonton AB Posts: 253 ![]() ![]() ![]() |
My EGR valve and cooler are gone as I have them mapped out as well, works fine.
SilverPuma Member Since: 27 Oct 2023 Location: Devon Posts: 51 ![]() ![]() ![]() |
Be interested in the outcome. I have an airlock in the heater matrix I think.
Hot coolant in supply hose to heater valve (just replaced AGAIN 🤬 albeit with an RDX one) but blower cold and hose from valve rear to matrix cold. Can shine a torch through the heater valve body and only 10% full of coolant. Be grateful for best way of unblocking as not clearing by running engine with bleed point opened / expansion tank cap off etc….. 2010 2.4 TDCI Puma Defender 90 |
Siwynne Member Since: 04 Nov 2016 Location: West lancs Posts: 609 ![]() ![]() |
A vacuum purge and fill tool is less than £30 on amazon. Needs a small compressor to run but they are very effective at filling without introducing air. I have One and it’s a no fuss one hit job guaranteed to be air lock free. ( if you keep the pick up tube submerged)
The fact your system is constantly "making air" is the concern. Mine did the same and was only resolved by a head and head gasket change. The head had micro-cracks that the shop said pressure tested just fine but I spoke with Turner and they have been selling a lot of heads so I decided to change mine as well. YMMV
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 2021 ![]() ![]() ![]() |
jb, this is what I'm thinking, initially the over pressure would happen only after at least a 2 hour run so thinking the head test would probably pass when cold. but I'm still not getting any reading on the RELD test? What's the cost of a new head?
Siwynne, ive actually got one which came with the coolant pressure test kit, might be worth a go? 2023 Defender L663 V8 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
not as bad as i was thinking!!
![]() 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
That's what I thought. Comes with the valves/springs/etc so it is all ready to go. There are bare heads cheaper but I went with Turner as they have a good rep.
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8324 ![]() ![]() ![]() |
This is what i have eluded too and concur with. Air is being introduced some where. What was the reason the head gasket needed tk be changed the first time? Had that issue that caused the initial failure been fixed yet? Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
I think you need to bottom out the cause of the coolant loss rhe first time it happened. I have just reared the posts and can't see that rhe initial cause has been rectified.
Is it mapped? If so by who? You can bypass the egr cooler with a piece of pipe Yes. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Late reply….working away again!!!
The initial symptoms were coolant cap discharging after at least a 2 hour run but other than that no other symptoms or issues on local or drivers under 2 hours, no coolant loss either. The only give away was the RELD test showing a colour change proving combustion gasses in the coolant after a hot engine. Hence the gasket change, also blanked the Egr cooler. Mapped by BAS around 9 years ago, BAS intercooler and silicone hoses. Going to try bypassing the EGR cooler again and inspect as many hoses as I can this weekend 2023 Defender L663 V8 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
Won't be the map then.
Looks to be same problem causing symptoms. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1856 ![]() ![]() ![]() |
Sounds the same as mine, pressure after 2 hours, cap didn't receive so blew the bottle and radiator.
Pulled the head off, and it was only after very carefully cleaning the chambers in the head with a scotch pad that the cracks were visible. +1 for Turners, told me the same that they're selling loads of 2.4 heads, also that they think tuning shortens head life(?) don't forget the new glow plugs, timing chain kit, etc - be rude not to as its all apart..! |
It’s got to be hasn’t it!
It’s had new chain kit, cover, glow plugs, turbo, water pump, vacuum pump, thermostat, coolant tank, CHT sensor…..probably forgot more! Going to the mech next week for a look 2023 Defender L663 V8 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
