Home > Faults & Fixes (L663) > Remove Wheel Arch Trim
JAM911
Hi Everyone
I need to remove my front wheel arch trims.
I watch the Powerful UK video on how to do it but they just pulled them off and broke them.
Anyone done this please and have any advice please?
I would get away with just prying them off the wheel arch a bit with out removing the completely.
Thank you
And if I need to get new clips does anyone have a source / part numbers please?
Post #1057997 20th Jan 2025 4:56pm
lightning
These parts are difficult to remove without breakage.
Sometimes the clips break, and you can replace them. But also the plastic can break.
Fortunately a new trim is not expensive and it's probably easier just to pull the old one off and fit a new complete trim.
l tried to save mine but broke two of the plastic clip holders.
Post #1058010 20th Jan 2025 7:03pm
F-Typical
Re: Remove Wheel Arch Trim
JAM911 wrote:
Hi Everyone
Thank you
Why do you need to remove - or pry them off a bit?
Post #1058039 20th Jan 2025 8:45pm
JAM911
A small section of wrap need sticking down
Post #1058041 20th Jan 2025 8:49pm
Defendit..
Netherlands
Press the white clips in from behind with a suitable small plier. Then one by one take the wheel arch trim off.
Nothing breaks this way but it has to be clean / mud and sand free before. No Mud flaps for my 90.!
P300S MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods..
Post #1058128 21st Jan 2025 2:18pm
JAM911
Thanks for the tip
Post #1058131 21st Jan 2025 2:23pm
lightning
l tried this on mine and still broke two clips but it must be possible.
Post #1058145 21st Jan 2025 6:42pm
F-Typical
A hairdryer might help I'm thinking?
Post #1058154 21st Jan 2025 7:21pm
JAM911
So I have taken the fool proof , well I hope so , way of doing it.
I ordered a new set of clips, £5 for 20 from Vehicle Clips
And I managed to find a brand new ( 20 miles on brand new car) set of front wheel arches in black gloss for £30 on FB Marketplace
So I can remove the existing ones without worry.
If you see the new ones for sale you will be able to tell I didn't break anything.
Will post the results.
Thanks
Post #1058169 21st Jan 2025 9:24pm
USCG23
United States
You definitely need the plastic pry tool and pull straight back. I didn’t break any of my tabs or clips. However I did when I removed my extended wheel arches. I broke two clips per side. lol Ohh well. 23 LBW/Urban Defender X
20 Velar Autobiography
Post #1062789 13th Mar 2025 11:34am
BadgerWaz
Use masking tape on your body panels so when you use your plastic pry tool (with a soft cloth behind it) you won't damage your paintwork.
I removed all of mine to replace with the LR extended wheel arches, and I damaged/broke none of them. The panbel clips do break though yet are replaceable and cost pence on ebay/amazon.
Post #1062793 13th Mar 2025 12:04pm
lightning
What is this plastic pry tool you speak of?
Post #1062811 13th Mar 2025 2:23pm
CincyRovers1
United States
Normal trim removal tools made from plastic, like these: https://www.amazon.com/dp/B0CF8WNBCJ/ref=t...8&th=1 𝟐𝟎𝟐𝟏 𝐃𝐞𝐟𝐞𝐧𝐝𝐞𝐫 𝟏𝟏𝟎 𝐒 𝐏𝟑𝟎𝟎 (Pangea Green over Acorn/Lunar)
𝟐𝟎𝟐𝟑 𝐏𝐨𝐫𝐬𝐜𝐡𝐞 𝐌𝐚𝐜𝐚𝐧 𝐒 (Dolomite Silver over Black/Bordeaux Red)
𝟐𝟎𝟏𝟕 𝐃𝐢𝐬𝐜𝐨𝐯𝐞𝐫𝐲 𝐇𝐒𝐄 𝐋𝐮𝐱𝐮𝐫𝐲 𝐒𝐢𝟔 (Aintree Green over Vintage Tan/Ebony) - Gone
𝟐𝟎𝟏𝟏 𝐋𝐑𝟒 𝐇𝐒𝐄 𝟓.𝟎 (Ipanema Sand over Almond/Arabica) - Gone
Post #1062815 13th Mar 2025 4:13pm
Clemmo
It’s just not worth the hassle…the clips are so cheap
The design is sacrificial
Just pull em off with your hands…no prying, no hairdryers…no damage.
For sure the little white monsters break…put new ones in!
That’s exactly what a JLR technician would do.
Thumbs Up
Post #1062845 13th Mar 2025 10:37pm
