Home > Td5 > Windscreen Washer
mpald
United Kingdom 2004 Defender 90 Td5 HT Keswick Green
Windscreen Washer
With quite a few weeks of cold and slightly damp weather, I think my patience has almost been exhausted by the windscreen washer system and its inability
a) to put a decent amount of water on the screen;
b) to squirt it in the right place; and
c) to catch the water effectively with the wiper blades.
There are no mechanical issues and it's all working - it's just all a bit underwhelming.
Obviously, there is the Optimill system with new jets, pipe, and pumps. Has anyone fitted this and is it worth it or is there another [cheaper?] alternative?
Any recommendations gratefully appreciated.
Post #1057828 19th Jan 2025 12:06pm
landy andy
Post #1057830 19th Jan 2025 12:09pm
Mo Murphy
Use 2 washer jets. Fit them where the LHD wipers go. Red topped (rear) washer pump.
Effective though not reassuringly expensive I'm afraid.
50 Shades of Pennine Grey
Post #1057833 19th Jan 2025 12:25pm
mpald
Thank you - that’s really helpful.
Does your new one do the job well?
And was it a straightforward swap? Possible to manage without taking the dash off?
Post #1057834 19th Jan 2025 12:25pm
landy andy
My Design Development one works far far better than the standard item. But I doubt as good as the Optimill option, and the cost shows that. I get about twice twice amount water, and I can get it where I want.
The CSI one looks like a good option, wasn’t about when I got mine.
I think they all involve some dash deconstruction and doubt for the dash bit that the different models are any different. Obviously the optimill is the most work as it is more than just a nozzle change.
Removing the one way valve (located by heater box) in the sytstem releases more power, and also stops the water freezing in the pipe. But longer press to get water.
Post #1057838 19th Jan 2025 12:46pm
Mo Murphy
It does the job very well. As regards fitting, it's quite simple, remove the 2 ends of the dash and the dash top. Every screen washer modification will require the dash top off.
Remember to judge spray pattern when you are driving not when stationary. The airflow over the front of your Defender will make them quite different.
HTH
Post #1057855 19th Jan 2025 3:36pm
sharkey964
France 2007 Defender 90 Puma 2.4 XS CSW Santorini Black
I have the Optimill washer system on my 110,it's good but could be better.
The flow rate is excelent,lots of water onto the screen,though,the downside of this is it empty's the reservoir very quickly,also though there are 4 jets,they are not adjustable,so,I find they spray a little too low on the screeen,meaning you have to let the wipers do 1 pass/wipe then squirt again to get water to then be dispersed onto the area of windscreen you need to clean.
I worked out a fix for this by blocking one of the jets with Sikaflex,the result being,the jets now squirt higher up the screen. Thumbs Up
Marc.
Post #1057856 19th Jan 2025 3:54pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
FWIW, simplest and least expensive fix I found was this…. LHD however I am certain a RHD set up would work just as well. Works as it should at any speed. Two dual jets on drivers side and single is enough on the passenger side.
Good luck
 2020 range Rover Mk IV Autobiography PHEV
2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #1058013 20th Jan 2025 7:11pm
I have an Optimill jet and it is great, however I found that it didn't get water above the driver's side blade and consequently the driver's side of the screen was difficult to clear. Because of this I fitted an additional quad jet (of the type in the eBay link below) to the offside arm. The result is spectacular and very successful but I can empty the reservoir very quickly! I am actually so impressed by the quad jet that I am considering fitting one on the nearside, which may render the Optimill superfluous.
I use a Disco2 headlamp washer pump for my screenwasher, and a second one (actually a similar headlamp washer pump off some model of MG Rover) for the headlamp washers. These pumps are bigger and significantly more powerful than the standard Defender pump but need some ingenuity to mate with the reservoir.
Link to quad jet: https://www.ebay.co.uk/itm/373830066003
Post #1058044 20th Jan 2025 9:06pm
mpald
Thank you - will have a look. Irritatingly and loudly, the prop shaft parted company with the vehicle yesterday and so a pressing repair will get in the way of improvements!
Post #1058677 26th Jan 2025 7:26pm
drakes
United Kingdom 2004 Defender 90 Td5 HT Auto Belize Green
I bought 2 used heated jets from a BMW and mounted them in the bonnet so you get a good spread of water, they don't freeze and you don't need to take the dash apart
Post #1059031 30th Jan 2025 9:00pm
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
Changing the pump can make a difference. A rear pump is more powerful than the front. I think there is a disco one or headlamp pump even stronger.
Post #1059032 30th Jan 2025 9:10pm
