Home > Puma (Tdci) > Puma pushing out coolant
Page 3 of 4 <1234>
andy63
Ahh that's still on my to do list.. I have a catch can to fit at some point..
when I said I thought the egr was responsible for the mess and carbon build up in the inlet side obviously the oil came from that side of the engine but I'm sure the exhaust gas just made it worse..
You are most probably aware that low pressure egr is now well established in the automotive industry..so regardless of load conditions on the engine there is pretty much always a flow of recirculated exhaust gas..
Anyway I have other matters to see to..
I had a warning light this morning..I'm hoping it's not the start of a load of bother..😫🫣👇
Post #1057665 17th Jan 2025 3:33pm
Ianh
Fuel filter, Tank pump, HP pump, VCV or fuel rail pressure sensor are areas to check.
Post #1057673 17th Jan 2025 5:50pm
Ianh
blackwolf wrote:
I am personally convinced that deleting the EGR and adding a Provent to the breather circuit is a simple way to extend the life of your engine by a significant amount.
I totally agree with Blackwolf, with the addition of mapping out and removing the DPF on the 2.2.
As for totally removing the EGR and cooler, unfortunately it’s an MOT visual inspection item. So mapping out, leaving in situ, blanking off each side of the cooler and removing cooler pipes and joining together is the most prudent solution. Also putting a faux DPF/CAT canister on the downpipe If mapping that out is needed as it is also a visual inspection item.
The main issue will happen if the basic smoke test is changed to monitor small particles and /or readings are taken from the OBD2 port regarding EGR and DPF. These sort of tests are conducted in other counties so a precedent has been set.
Post #1057674 17th Jan 2025 6:06pm
andy63
Cheers Ian..
I've had a quick look and got this.
I've cleared the fault but I'm not holding my breath that it will stay away..😫
Post #1057681 17th Jan 2025 6:34pm
Peterd
England 2013 Defender 110 Puma 2.2 XS CSW Bonatti Grey
I have similar issue. Coolant loss through expansion tank. I removed the egr cooler which was found to be leaking. Replaced with a new cooler and valve. Still failing a co2 test so suspect HG is leaking as well
Question is what to do next.
I am thinking replace with brand new engine. May sound overkill but at around £4k would surely be worth it. I am tempted to start stripping the engine to find the issue and attempt the repair with the worst case scenario being the new engine.
Does anyone know if the HG repair can be done without de gassing the AC. If it does need to be de gassed and removed then I would want to do this before I start stripping as I can drive it short distances in its current state.
Post #1057690 17th Jan 2025 8:36pm
stichill99
head gasket
I would think you would not get away with out taking any air con pipes out the way, To take the cylinder head off you basically have to strip everything out the engine bay to get at all the nuts and bolts!
Post #1057695 17th Jan 2025 9:18pm
Peterd
That’s what I thought. More hoping someone would say otherwise.
Post #1057696 17th Jan 2025 9:24pm
Ianh
Unfortunately a leaking EGR cooler can cause the head gasket to fail, I suspect that’s what happened to you.
Post #1057698 17th Jan 2025 9:33pm
stichill99
head gasket
When our egr cooler failed and the header tank was passing coolant under high pressure when we took off the cylinder head the gasket was in perfect condition!
Post #1057749 18th Jan 2025 4:35pm
Ianh
Unfortunately it’s hit and miss, some get lucky an No HG failure, some don’t.
Post #1057775 18th Jan 2025 9:13pm
ickle
I put a new head on 12 months ago and had no issues with the air con, everything moved out of the way with room to spare.
HTH Keith
Post #1057781 18th Jan 2025 9:45pm
Peterd
Ac has now been de gassed. After chatting to the guy at the garage that carried out the de gassing. He suggested using steel seal liquid head gasket repair. Not an option I really wanted to do but is there any harm in giving it a go. What is the worst that could happen.
For curiosity I would like to try.
As far as I can see all I would have to do is drain and flush cooling system. Fill with plain water. Add chemical. Run to temperature plus 30mins at idle. Leave to cool. Drain system and re fill with coolant.
Post #1057809 19th Jan 2025 8:48am
Peterd
Re: head gasket
Did you establish where the fault was
Post #1057810 19th Jan 2025 8:59am
andy63
I'll bet that I'll be saying what most folk will be thinking..
If you are going to do the job do it properly..🫣🤣
But I'd never say no don't use it..
Way back i had similar views on the cooling system fixes like radweld..
Can't remember exactly why I eventually tried it... (most probably cost and not been able to afford a new radiator ) drove me down that road and to my surprise the fix was good and ended up not been temporary but a permanent fix...👍🤣
So if I was i in the same position or on an expedition and it was a last resort I'd try the fix. Only then can you have a indication of its effectiveness
but my instinct still takes me to my first comment above..👍
Post #1057813 19th Jan 2025 9:38am
Peterd
I am definitely with you on if a jobs worth doing.
I am going to do it to see if it works and then probably do the work anyway.
Post #1057815 19th Jan 2025 9:46am
Page 3 of 4 <1234>
