![]() | Home > In Car Electronics > Defender wiring problems with cigar lighter |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21015 ![]() ![]() |
Fuse might be blown, the factory set up has fused power supply, ground and illumination live.
The wiring colours you’ll have to consult the wiring schematic for that, you can also use a multimeter to check for voltage, obviously the illumination is only supposed to be on when sidelight or dipped is, the power when ignition is on. The fuse for the supply has possibly* been blown, there isn’t a Relay involved, the fuse is under the steering wheel in the factor fuse box. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Alex2000 Member Since: 23 Mar 2020 Location: North Yorkshire Posts: 12 ![]() ![]() |
I’ve checked the fuses and used a multimeter but not when the light where on I’ll check that
Do you mean in the middle under the radio fuse or is there hidden ones behind the gauges I do t know about Thanks |
Roverdrive Member Since: 11 Aug 2024 Location: Wirral Posts: 26 ![]() ![]() |
Alex
This link might help you. https://www.autosparks.co.uk/media/Autosparks%20BSCC.pdf Red and light green is screen wiper motor to switch Red and yellow is the fog lamp Black is earth Brown is permanent live Cant tell if the darker greens have a tracer but plain green is accessories fused via ignition switch. Hope this helps Mike |
That link is useful thanks 👍
My brown has no power. Just need to check the side light wiring still and the only 12v ignition is the green wire |
