Home > BMW Engine Conversions > M57N with 8hp70
Les Brock
M57N with 8hp70
Hi Guys
M57 from X5 with F Series HP70 controled by Cantcu
Still WIP as I'm an old fart and things keep getting in the way but nearly there ...
Had loads of help along the way from Mo and James
Post #1057291 13th Jan 2025 8:20pm
90dv
United Kingdom 1990 Defender 90 200 Tdi CSW Keswick Green
Any more details how you have fitted the Webasto heater? Just about to embark on fitting an M57 myself and want to put the webasto I have in as well.
Thanks
Post #1057308 13th Jan 2025 10:20pm
jst
What servo is that Les?
M57 won't need a webasto for getting to temp quickly for the heater. But they are useful for prewarming engine mines fitted same as yours les.so much more room in an m57 bay. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1057383 14th Jan 2025 7:36pm
jst
Under drive or diff lock lever to side? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1057384 14th Jan 2025 7:37pm
Les Brock
James,
Servo I bought as a TD5 early Non ABS Ex Stock off Ebay with the expectation of fitting LoF Booster to it, arrived in Genuine LR Box with NSN Number on it, opened to find it already had adaptor on it already and it fitted staight to pedal box
I'm assuming some MOD special for 300Tdi that required extra bracking effort of double servo or indeed very early TD5 poss when ABS was option ? - I did take some pics of part numbers/box if I can find them.
Post #1057394 14th Jan 2025 9:29pm
Les Brock
Thanks
No problem what can I help with, how I plumbed it in or electrics/fuel pick up ?
Post #1057395 14th Jan 2025 9:30pm
Les Brock
Its for the underdrive, currently it's still sat in the box, seeing if its worth fitting or if I'll ever use it again lol
Post #1057397 14th Jan 2025 9:32pm
jst
Nope! Sold mine with last truck. Auto won't need it anyway. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1057411 15th Jan 2025 12:41am
jst
James,
Many would be good if you do find them. Looks like abs one. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1057412 15th Jan 2025 12:42am
Les Brock
James
3 port cylinder on this the ABS one is only 2 port if memory serves me correctly
Post #1057427 15th Jan 2025 9:05am
tommobot
Re: M57N with 8hp70
Les Brock wrote:
Hi Guys
Do you by any chance recall what top hose you've used heading into the radiator?
Can't find something that nicely clearlys the power steering unit - Would almost like a smooth S profile..
I've got a very similar pipe, but it is twsited and doesn't sit quite as comfortably (I'd used a spare hose I had knocking about)
Post #1057434 15th Jan 2025 11:31am
90dv
Les Brock wrote:
Thanks
Both really, how have you plumbed it? Is it inline with the heater? I wasn’t sure if the Webasto was free flowing when not on.
Do you have a separate Webasto timer/controller for it?
Thanks
Post #1057443 15th Jan 2025 2:01pm
jst
Webasto has a through pump so can be inline and not running. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1057523 16th Jan 2025 12:03pm
jst
Les, what's the rest of the vehicle? Tc, hard top, sw?
Just thinking of buying it when you have finished as you normally sell them pretty quickly.... Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1057565 16th Jan 2025 5:55pm
Les Brock
Rolling with laughter
TBF the others went due to me getting Divorced and well they had to so I could start over, had this since 2011'ish and my recently last build....... times catching me up and at 61 I'm getting to old to be building, this was why it was mission creep as I only wanted to do it once.
This will be a keep and maintain to keep my hand in.
Thank you for wanting to buy it and having confidance in my building ability Whistle Wink Twisted Evil Thumbs Up
Post #1057585 16th Jan 2025 9:02pm
