![]() | Home > General & Technical (L663) > How renew Remote subscription on the App ? |
| markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2704
I would say that it would be worth talking to your local dealer or even JLR customer services.
The frequently asked questions says that it should have started working for you straight away, so there is an issue ‘their’ end I would say. Alternatively you could delete the app and reinstall it to ensure that you have the up to date version. Hope this helps |
| WizzardPrang Member Since: 05 Nov 2020 Location: Hertfordshire Posts: 182
You should be able to see all your subscription options on the inControl portal:
https://incontrol.landrover.com If it doesn't show the option to renew, then as per marcb110's suggestion, perhaps LR Customer Service could help. Current vehicle: 2020 Defender 110S Gone: Defender 90 HT 200Tdi, Discovery Sport, Freelander 2 Insta: wizzardprang |
| Gareth Member Since: 12 Dec 2011 Location: Woodford Posts: 1142
Mine has expired, but I can still use the LR app, with remote heat/lock etc.
What I have lost is the functions such as live traffic on the sat nav, weather, parking apps on pivi. However I never used them, and use CarPlay instead. 2021 Defender 110 X-Dynamic HSE D300 MHEV 1966 S2a 109 aka Betsy |
| DC-Defender Member Since: 23 May 2024 Location: USA Posts: 11
My Online Pack with Data Plan recently expired, but I never received the renewal email. I reached out to Land Rover Support and requested to open a case to get the renewal link. The representative was very helpful and handled it right away, sending me the renewal link on the spot.
Since I’m located in the United States, my renewal link contained "en_US". However, in your case swapping it with "en_GB" should redirect you to the correct renewal page where you'll see your subscriptions up for renewal and you can add to basket and pay (I tested it and landed on the web page without my VIN entered). Just replace "en_US" with "en_GB" and where it says "YOUR_VIN" put your actual Defender VIN and see if it works: https://shop.incontrol.landrover.com/en_US...n=YOUR_VIN If the link still doesn’t work, then call Land Rover Support and tell them you want to open a case to obtain the renewal link for your subscription. Hope this helps you and anyone else that finds their way here. |
