Home > Maintenance & Modifications > is something wrong or is it me???
dans_defender
 2011 Defender 90 Puma 2.4 HT Baltic Blue
Afternoon all,
Need a bit of guidance as beginning to doubt my own sanity!!
I have a 2011 90 2.4TDCi hard top. Owned for 3 years has about 86k on it. Serviced religiously etc. Never been properly off road.
The last 5-6 months it's driving differently. Feels loose, unstable and generally a bit wobbly. Serviced and MOT back in December and passed with no issues.
Where do I start with fault finding???
Plan is to upgrade shocks, springs, bushes etc at a later date when funds permit.
One thing that has rung alarm bells is that it's still on original tyres, albeit plenty of tread on them.
any help would be really appreciated.
thanks
Dan
Post #1056919 10th Jan 2025 4:02pm
andy63
I'd start by getting it jacked up ad go round the wheels and various suspension parts with a pry bar to see if it has any play on the various joints .. does it have anti roll bars ?
Check the prop shafts and diff slack ans see if you think its excessive..
Does the engine running smoothly ?
I know you said it passed its mot but that's where I'd start.👍
Post #1056927 10th Jan 2025 4:30pm
Ianh
Have a look at your front axle, in particular the nearside welds, are there any cracks, is there any loss of oil, does your axle full within the recall range.
See https://www.defender2.net/forum/topic33029...;start=510
Post #1056928 10th Jan 2025 4:41pm
ickle
Check axle first as above - my best guess would be panhard rod bushes but if you treated it to a full set of bushes & a decent set of shocks etc it would feel better than new again!
HTH Keith
Post #1056963 10th Jan 2025 8:19pm
markb110
Mine turned out to be the swivel pins.
It’s worth speaking to your local independent otherwise you could end up chasing your tail and spending money ‘on the off chance’.
At the same time I also got them to fit the Gwyn Lewis steering kit.
Good luck
Post #1056964 10th Jan 2025 8:28pm
Have you noticed it more since it’s been really cold? If so, with the cold especially under about 5.C all the rubber bushes get a bit more harder, so can feel a bit more different.
All you can really do is look for play in the bushes, I find rear damper ones are quite a common nuisance, steering component ball joints, steering damper etc is worth looking at. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1056969 10th Jan 2025 9:05pm
Ianh
Check the A frame ball joint, that can cause quite a wobble. It sits on top of the rear axle.
Post #1056978 10th Jan 2025 9:46pm
